You view box
Peter1005
Message 3 of 3
My you view box which I have had for many years has stopped recording, playing back and I cannot switch channels, I have tried all troubleshooting to no avail.
I need a new box how do I get one?
Message 1 of 3
Hi Peter,
How are you getting on?
Message 2 of 3
You say you have tried all options to rectify
To clarify, have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
As for a new box, you will need to phone and probably recontract to obtain a new box.
Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
Hope it works and please let us know how you get on.
