talk talk box volume fluctuates with out promting
Keybop
Message 5 of 5
volume rises and falls on its own
4 REPLIES 4
Message 1 of 5
Try a Youview Maintenance Reset  and see if this helps.
Message 2 of 5
Is this recent? There has always been a fluctuation between HD and SD broadcasts. Is this what you what are noticing when you change channels or is it at random times?
have you tried changing batteries?
Have you tried resetting the remote. Instructions can be found by using the search bar.
Are the volume buttons sticking if you try to change the volume. If so try cleaning with a wet wipe.
Let us know how you get on.
Keybop
Message 3 of 5
My box is a Huawei DN372T about 4 years old
Message 4 of 5
Which box do you have so we can offer specific advice?
