on 22-04-2024 09:39 AM
I have new router (joined April 11th) and everything is working fine except the 5GHz band. Discovered this through my LSX II KEF speakers. I need to switch these on/off frequently to reconnect. Checking my router 5 GHz had nothing connected. Most of the equipment switches to 2.4 GHz (like my iphone) but the KEF's are locked to a band.
on 31-05-2024 09:40 AM
Hi @ianfirth99
If you want help, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
on 31-05-2024 09:33 AM
I am having exactly the same issue with the 5Ghz network dropping but the 2.4Ghz remains on.
From the router dashboard the 5Ghz shows as being on but is not visible on any devices.
Only a router reboot will fix the issue.
Any help would be appreciated.
I have been a Talk Talk customer for just over a month and this is not a very good start
Thanks in Advance
on 25-04-2024 02:51 PM
on 25-04-2024 02:25 PM
They work on both bands, but only 1 at a time. KEF recommends 5 GHz for reasons of bandwidth, they also recommend to rename the SSID (to prevent automatic switching) and band steering (if that is the correct term).
Further I have disabled MAC filtering completely and fixed the channel (no auto)..
on 23-04-2024 04:25 PM
Hi @Andries
Do these speakers only work on the 2.4GHz band only? If so, I am puzzled as to why you think that the 5GHz band is dropping.
on 23-04-2024 04:18 PM
Hi Keith it's a Sagecom 5364 and the speakers are KEF LSX II, they have advised me to go back to 2.4 GHz to see if the issue persist. I am happy to do that, but it wouldn't really solve the issue of course.
on 22-04-2024 03:02 PM
Hi @Andries
@Debbie-TalkTalk has asked me to help you. First of all please can you tell me the make & model of the router that you are using?
on 22-04-2024 02:23 PM
Hi Andries
Our Community Star @KeithFrench provides really good advice on improving wireless performance. Could you help please Keith?
KeithFrench is one of our valued Community Stars and can help with a range of issues related to wireless and networking. At times he may ask you to send him test results via a Private Message to help analyse/diagnose an issue. Although Keith does not work for TalkTalk, he very kindly shares his time and knowledge to help with others. If you need further help or, if we need to take any details such as personal information about your account like phone numbers, account numbers etc. one of the TalkTalk team will jump in and help out.
on 22-04-2024 10:19 AM
Sorry new on the forum, but found the reply button 🙂
Yes I did previously split as this is a recommendation from KEF.
Basically I alwyas identified the 5 GHz as a separate network to manage the load,
on 22-04-2024 10:12 AM
Yes did reset, I've been ongoing experimenting with router settings to get it working (like cancelling MAC filtering) etc. To no avail.
Previous router from UW had no issues.
on 22-04-2024 10:07 AM
And split the names into one that identifies as 5GHz (also KEF recommendation).
on 22-04-2024 10:06 AM
Hi Andries
Thanks for confirming.
Did you previously split the SSID's on the router?
on 22-04-2024 10:04 AM
Sure, several times. Also cancelled bandsteering (as KEF recommends).
When I looked in the router there was nothing connected this morning (should be 3 devices)
on 22-04-2024 09:49 AM
Hi Andries
Have you tried resetting the router? (pin hole reset for ten seconds)
