Amber flashing light on Router: No connection
jakeg
Message 3 of 3
Hi there
This morning my WiFi dropped with no warning and I haven't been able to get it working since.
The router shows an amber flashing light which I take it means that it's trying to boot up, however it's not getting passed this stage.
I've tried the typical troubleshooting options as I've seen that this is an issue that others on here have experienced before, however to no avail. And it seems from looking through similar posts that a replacement router is generally what fixes it.
I do believe it to be an issue with the router itself as my landline still seems to be working fine.
Nothing on it has been tampered with and I've had no recent power cuts so I'm unsure what could've caused this failure.
Any advice appreciated
Thanks,
Message 1 of 3
I'm sorry for the delay. I've run a test on the line now which is clear. Have you been able to connect since your last post?
jakeg
Message 2 of 3
Turns out the internet is down for my neighbours too so it appears to be a wider issue
