on 10-01-2022 10:34 PM
My internet was working fine but upon restarting my laptop it asked for the password and said that it was incorrect. I then switched the router off and on and now the internet is not working and the internet symbol on the front of the box is amber. I have switched it off multiple times and pressed the reset button to no avail.
on 11-01-2022 09:29 AM
Hi Hazel_
Thank you. The router is on its way, please allow 24-48hrs for this to arrive.
on 11-01-2022 09:23 AM
on 11-01-2022 09:18 AM
Hi Hazel_
Have you added the correct landline number to your Community Profile? (please do not post the number on this thread)
on 11-01-2022 09:15 AM
on 11-01-2022 09:13 AM
Hi Hazel_
Would you like me to send another router for testing?
on 11-01-2022 09:08 AM
Yes, have held it in for over 10 secs but there was no change to the lights during this process to indicate that it actually reset
on 11-01-2022 07:02 AM
Hi Hazel_
I'm sorry for the delay.
Can I just check, did you complete the factory reset (pin hole) for a full ten seconds?
11-01-2022 05:02 AM - edited 12-01-2022 04:50 AM
If you reset your router, or if it happened accidentally, then the network might have defaulted back to the original password. Default passwords are usually a long string of random numbers and letters, so it can be easy to accidentally enter a typo.
on 10-01-2022 10:45 PM
Ok, when you tried the reset switch did you hold it in for over 10 seconds, that will ensure it actually does a full factory reset, if that still doesn't help then the staff here should be able to help in the morning. They will be able to run a test on your connection and your router, if they think the router has developed a fault they would be able to arrange a replacement for you.
on 10-01-2022 10:43 PM
Hi @Skynet_TX
Thanks for getting back to me!
the router has multiple symbols on the front, the one for the internet is a planet like Saturn, it is solid amber, no flashing. The only other lights on were solid green for power and ADSL, also depicted as symbols
I will make sure to update the details on my profile, thank you!
10-01-2022 10:40 PM - edited 10-01-2022 10:41 PM
Hi @Hazel_,
What model of router do you have, is it one that just has a single LED on the front, if so is the amber light solid or flashing ?
When you say it asked for a password, do you mean the laptop was asking you for the Wi-Fi password for it to connect to your router ?
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk staff on this community can see your profile details).
