BroadBand connection suddenly spiking and dropping
NathanGray
Message 32 of 32
Hi there, ever since yesterday I have noticed something quite out of the ordinary happening with our wifi connection. It has been fine for months and I would say close to perfect, but ever since yesterday it has been having these quick spikes kicking us off things that we are using and our MS on certain applications like discord going to over 5000.
I was just wanting to know if there's an issue going on in my area? or just in general as I cannot get onto the live chat to talk about the issue as it is telling me that all the Agents are busy.
It is not just contained to one of my devices either, it seemingly effect's every device in the house at once during one of these spikes.
Nathan Gray
31 REPLIES 31
Message 21 of 32
Awesome, will do.
Nathan Gray
Message 22 of 32
Hi Nathan
Thanks again,
Message 23 of 32
Yeah that would be fantastic, thanks.
Nathan Gray
Message 24 of 32
Hi Nathan
This would be a Sagemcom WIFI hub, will this be ok?
Message 25 of 32
Hi there, that would be splendid.
We are currently on the full fibre plan with the sagecom router, although I'm not sure what model we are meant to have.
Would you be able to check that for me too if possible? We've had a few salesmen from talk talk come around and talk about the new WiFi 6 one on the full fibre plan so it's confused me a little bit too.
But we are currently using the Sagecom Talk Talk router.
Nathan Gray
Message 26 of 32
Hi Nathan
I've completed a line test which is clear. Would you like me to send a replacement router for testing so we can rule this out?
Message 27 of 32
We usually always have it turned on because it's recommended to do so if I'm thinking correctly.
Nathan Gray
Message 28 of 32
Good morning
My router is currently switched on
Nathan Gray
Message 29 of 32
I'm sorry for the delay. Is your router currently switched off?
NathanGray
Message 30 of 32
Iv tried resetting the gateway on my router and rebooting it to no luck, I'm really not sure what else I can do.
Nathan Gray
NathanGray
Message 31 of 32
Just as an update this is still an issue.
I went to check my routers Maintenace logs and it has
Date/Time : 20.11.2022 16:36:57
Severity: warning
Module: DHCPC
message: WAN DHCP client(1)  stopped
Nathan Gray
