on 30-05-2025 06:00 PM
For the past 4 months I have been facing a problem with my broadband connection it keeps disconnecting every 10 minutes and start to flash orange and turn back on
on 12-06-2025 07:22 AM
Hi @30gSterling best way is to start your own thread and clearly stated your issue. Saves you, support team, and the original poster a busload of unnecessary work.
on 12-06-2025 07:18 AM
I have the same problem. Any way to fix this?
on 03-06-2025 08:37 AM
Hello there @Kadah, just checking to see if you still experiencing any issues with your broadband connection. Kindly let me know if you have received this message.
on 02-06-2025 10:11 PM
Yes it keeps disconnecting then it comes back on after but this is happens between 20 to 25 times a day it just keeps disconnecting
on 02-06-2025 05:03 PM
Okay so you do get your internet working fine then get a connection dropping out then comes back again, is that correct?
-Fez.
on 02-06-2025 04:53 PM
disconnection
on 02-06-2025 01:03 PM
Thank you for getting back to us, we will need to run line checks to help us determine the main cause of the issue and a possible resolution to it. Please confirm if you have no internet access at all, have slow speeds or dropping connection?
-Fez.
on 02-06-2025 12:52 PM
The internet has been in this condition for 10 days.
on 02-06-2025 12:51 PM
The network is back up and running. It's unbearable.
on 02-06-2025 12:49 PM
I was out of the house now the internet is down
on 02-06-2025 09:07 AM
Thank you for getting back to us, we will run checks for you to help us determine the main cause of the issue and a possible resolution to it. Are you currently home where the services are?
-Fez.
on 02-06-2025 09:03 AM
More than 10 times a day and it takes time for the connection to return
on 02-06-2025 08:20 AM
Hi there @Kadah , thank you for reaching out to us, we are so sorry you have contacted us about an issue with your services, how often do you experience this problem?
-Fez.
on 30-05-2025 07:17 PM
Hi @Kadah thanks for starting your own thread, unfortunately its Friday and the support team will not be back in till Monday.
Your post has been escalated.
Do you by any good fortune have a spare router and power supply you can try?
