Broadband solid amber light
Cookies2021
Message 8 of 8
Hi all, our broadband has all of a sudden stopped working, there is a solid amber light, I have restarted it and still no luck, any advice please?
7 REPLIES 7
Message 1 of 8
Hi @Cookies2021
I'm so glad to hear this.
Please let me know if you do experience any further issues.
Message 2 of 8
Everything is working fine now thank you!
Message 3 of 8
HI @Cookies2021
Apologies for the delay.
The line test is clear, no faults detected.
Is the connection still dropping this morning?
Message 4 of 8
I have tried to reset through pin whole a few times and it is still not working.
Cookies2021
Message 5 of 8
Hi Debbie,
The service status is good.
Message 6 of 8
I'm sorry to hear this. Have you checked our service status page for any issues in your area Service Status | TalkTalk Help & Support
Message 7 of 8
Unfortunately there is not a lot you can do. You could try a pinhole reset by putting a pin in the hole on the back until the router restarts.
You are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
