on 07-07-2022 07:45 PM
Please can you look at my broadband settings. My speed has been getting slower over the past couple of weeks, to the point that now just browsing is difficult, and streaming is impossible.
Thank you
on 11-07-2022 09:27 AM
How have you found the speed/overall connection since the line optimisation? Is everything now ok?
Thanks 🙂
on 08-07-2022 07:17 AM
I'm sorry to hear this. I've optimised the connection now and the sync speed has increased. Are you experiencing any noise on the voice service?
on 07-07-2022 08:26 PM
Hi @MichaelS12345,
If you go to the Service Centre what does it show for your ‘Estimated Speed’ and your ‘Measured Speed’. If you run a speed test (ideally from both a wired and wireless device so that you can compare), how close are the speed test results to that ‘Measured Speed’.
It would be worth going to the Service Centre to run a connection test on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
If your master phone socket has a test socket then you could also try the router in there (via a microfilter), that would then eliminate any of the phone wiring in your home as being a possible cause of the problem (although you may need to leave the router connected at the test socket for 72+ hours before you would start to see a speed increase if this was the cause of the problem).
The TalkTalk Support Team on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
