on 04-07-2022 11:06 PM
Good evening,
Normally we get a download speed of nearly 3mbps, but at the minute we’re closer to 1mbps. It's very stable but obviously the drop makes a difference at these speeds. Tests are with no other appliances connected and all sockets have filters. The landline is working and a quiet line test was silent. I've tried turning the router off for a period but the speed settles back to 1mbps when turned back on.
Last time someone reset the line and optimised DLM for us which worked great. Is it possible to do that again please?
Thanks in advance,
Richard
on 11-07-2022 09:21 AM
I can see that the sync speed has started to increase. How have you found the connection/speed over the weekend?
on 08-07-2022 03:53 PM
DLM is set for overnight optimisation so we can see if it improves over the weekend.
on 08-07-2022 03:45 PM
Thanks Karl,
It’s gone back up to about 1.5mbps now, does it normally take a while to get back to full speed?
Richard
on 08-07-2022 01:14 PM
I've reset the port and optimised the connection, see if this helps.
on 08-07-2022 01:06 PM
Hi Michelle,
The engineer’s been and fixed the fault but the speed’s still the same. He said to ask for the line to be reset at your end if that’s possible please?
Thanks for your help,
Richard
on 08-07-2022 12:23 PM
No additional update received back as yet, however we will continue to monitor this. Have you seen Openreach outside today?
on 07-07-2022 12:19 PM
Update received to advise that a line engineer has been scheduled for 08/07. This will be an external line investigation.
on 07-07-2022 08:07 AM
No problem. Hopefully we'll know more soon.
on 07-07-2022 08:04 AM
Thanks Michelle
on 07-07-2022 06:15 AM
I've checked and the fault is still under investigation with Openreach at the moment. We will check again later on this afternoon.
on 06-07-2022 06:44 AM
Thanks for checking this. The line test has detected a potential voice fault so I've passed this over to Openreach now to complete an external line investigation. We will check this again tomorrow morning to see if there are any updates on this fault.
on 05-07-2022 06:02 PM
Hi Michelle,
Thanks for getting back to me. It seems the phone has gone off now as well, even when plugged into the test socket. I ran a line test before and that flagged up a problem too. Is it something an engineer would have to look at?
Richard
on 05-07-2022 07:34 AM
I've optimised the connection now but the sync speed hasn't increased. Is the voice service ok? Does your main socket have a test socket please?
