on 16-12-2024 04:36 PM
I have the Fibre 500 package for well over a year now. It seems to work fine on some devices but on others certain apps and sites don't load or work.
On my laptop everything seems to work okay, but on my phone the banking app doesn't work. My housemate has more trouble - he cannot access lots of websites on his computer such as BBC iplayer and can barely use the wifi on his phone at all.
09-06-2025 03:06 PM - edited 09-06-2025 03:07 PM
Ok, thanks for the information @Iolaire. That router has no way of filtering content, so that is not the cause. Have you checked your MyAccount for the HomeSafe/KidSafe section, as I have suggested before?
on 09-06-2025 01:46 PM
It's Sagemcom FAST 5464
on 08-06-2025 04:03 PM
OK, please can you confirm which hub, there are four of them. There is a label on the rear of the router, behind the pull up panel:-
Hub 1: Huawei DG8041W
Hub 1: Sagemcom FAST5364
Hub 2: Sagemcom FAST5464
Hub 3: Sagemcom (not sure of the model number off hand)
on 08-06-2025 03:48 PM
We tried to set up the Eero but it doesn't work at all. We use the hub instead which works mostly fine for me, (save for my banking app and recently seemed to not want to sign into my phone account) - but my housemate is having a lot more trouble with the internet on his laptop.
on 06-06-2025 08:43 AM
Hi @Iolaire
I am confused then, you say that you have the WiFi Hub, but back in post 27 you said:-
Unfortunately neither me or my housemate are having much luck with the Eero. It only seems to be supported by phones and both our phones are quite old. Would there be a way to resolve this without the Eero?
Whatever, did you login to your My account and check there as I suggested. There is no content filtering in the WiFi hub.
on 06-06-2025 08:06 AM
Hi there. Thanks for that support @Gliwmaeden2
on 05-06-2025 10:17 PM
You'd need to start all over again phoning Talktalk for support, or use Chat, @Iolaire.
Contact details are here:
Forum staff cannot call you. They are authorised to work purely online, in the community set up on here.
on 05-06-2025 10:03 PM
would it not be easier to resolve this if someone gives me a call?
on 05-06-2025 10:02 PM
No, I don't use the Eero. I am using the TalkTalk wi-fi hub.
on 05-06-2025 11:49 AM
You're very welcome Fez.
on 05-06-2025 10:18 AM
Thank you very much @KeithFrench for the support, we will be awaiting for @Iolaire to get back to us.
-Fez.
on 05-06-2025 09:38 AM
Hi @Iolaire
@amahle-TT has asked me to help you.
From what I understand, you have one or more eeros, but you cannot run the eero app. How did you set the eero up in the first place?
There is a possibility that the eeros are blocking these sites if Safe Search is setup within eero Secure via their app.
Another place that this could be happening is via Home Safe/Kids Safe within your MyAccount configuration, nothing to do with the eeros. Please log in to MyAccount & check there.
05-06-2025 08:53 AM - edited 05-06-2025 08:53 AM
Hi @KeithFrench, any advice for this issue? 🙂
on 04-06-2025 07:27 PM
I wasn't at that time, I should be for the next couple of days most of the time.
on 03-06-2025 08:24 AM
Thank you for confirming, please also confirm if you are currently at home? Thanks
on 02-06-2025 08:39 PM
Yes I am
on 02-06-2025 09:20 AM
Hi there @Iolaire, thank you for your patience, there are no reported related issues, please let us know if you are still having the same problem.
-Fez.
on 01-06-2025 12:13 PM
Yes, thank you very much.
on 30-05-2025 06:08 PM
Thank you, I do remember you have mentioned when you reported the issue that this started since moving to TalkTalk Fibre, please allow us to investigate this and check if there are any related issues and if not, we will look into this further for you and get you help. Is that okay with you?
-Fez
on 30-05-2025 06:03 PM
According to my housemate who is the one experiencing the most issues, it's been a problem for as long as we've had TalkTalk Fibre which was about three years ago.
