Connection drops - over last few days
abntt7
Message 14 of 14
My connection has been stable for years. Since last week its been dropping out for a few minutes then coming back. This could happen 3 or 4 times before it becomes stable again.
Have powered off the router etc.
The connection seems to be dropping at the BT Openreach fibre 150 device, as the lights go off there, before coming on stable again
Did a line check and it did say fault found
13 REPLIES 13
Message 1 of 14
Hi abntt7
I'm so glad to hear this 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Message 2 of 14
Its been good since, so hopefully that's sorted it!
Message 3 of 14
Hi abntt7
Openreach have now closed the fault as resolved - Copper Overhead Network - Dropwire Pole.
Is everything working ok now?
Message 4 of 14
Hi abntt7
Has the Openreach engineer contacted you today? We are waiting for the engineers notes to be updated.
Message 5 of 14
Hi abntt7
The fault has been assigned to a line engineer this morning. We should hopefully have more information/updates later this afternoon.
Message 6 of 14
Hi abntt7
This fault is still with the Openreach line engineers, there are no further updates at the moment.
I will continue to monitor this for additional updates.
Message 7 of 14
Good afternoon,
Thank you for checking this. The line test is still detecting a potential voice fault so I've raised thist straight over to Openreach to complete an external line investigation. This can take between 48-72hrs, however we will check for an update on the fault first thing on Monday morning and will post an update back here.
Message 8 of 14
Ok plugged in a handset.
There is definitely a background buzz/whirring sound i can hear
Internet did drop once when i made a call from the handset but might have been coincidence as it was having one of its sessions where it keeps dropping.
Which seems to be the trend. Most of the time its solid, and then it will go up and down a few times within 30 mins
ta
Message 9 of 14
Hi abntt7
Thank you. Please let us know how you get on.
Message 10 of 14
Sure. Will borrow one from work
ta
Message 11 of 14
Would it be possible to borrow a handset just for testing purposes as a voice fault can affect the broadband connection and we would need to raise this first?
Message 12 of 14
Thanks for checking
We never have telephone connected to the wall socket (dont even have one anymore), so can't test
Andy
Message 13 of 14
I'm sorry to hear this. I've run a test on the line now which has detected a potential voice fault. Just to confirm, are you experiencing any issues with the voice service such as no dial tone or any noise on the line?
