Why am I constantly being disconnected ?
Vipersan
Message 20 of 20
This is not the first time I have suffered this problem.
It started again about 3 days ago....
The Router disconnects my service...usually in the middle of a movie..which is annoying and frustrating.
Re-setting the router by powering down and on adain usually fixes this...but it is now happening about 3 or 4 times a day.
Today for example I was disconnected (red light on router which is usually green when connected)...disconnected at 9:00 AM ..then again at 6:00PM ...9:10PM and 9:45 PM..
Once reconnected I do a speed check...which is acceptable ...currently 13.2 MBPS and upload 0.72MBPS.
But WHY does this keep happening ?
As I said...I had this problem last year...and up to 3 days ago..all was good..but now I feel like I'm being singled out for bad service ?
Please help if you can.
19 REPLIES 19
Message 1 of 20
That's great news Evan, thanks for letting me know
Vipersan
Message 2 of 20
As of today 14th Nov...connection has been reliable.
Hopefully This continues following the installation of the replacement router.
I will only post again to this thread if the problem comes back.
Thanks to all for your help.
rgds
Evan
Message 3 of 20
Good morning,
Thanks for the update and I'm glad to hear that the connection has remained stable 🙂
Vipersan
Message 4 of 20
So far so good Chris...up to now my connection has remained solid with the replacement router.
I'll report again next weekend or sooner if the connection fails.
regards
Evan
Vipersan
Message 5 of 20
Very informative thanks Chris
Message 6 of 20
The type of authentication shouldn't cause any issues but the fibre services (FTTC and FTTP) do tend to have less issues as they replace some or all of the old copper cables from the home to the exchange with optical fibre
Vipersan
Message 7 of 20
Indeed I will Chris..
It does make me wonder though ..since I am still using password identification...and in a minority in this.
If this is perhaps why I am experiencing periodic disconnection issues ?
Maybe the 'system' doesn't readily accommodate us old system users.
The ISP has changed hands a few times since I signed up with Pipex many many years ago.
regards.
Message 8 of 20
Hi Evan,
I'm sorry, I know it's not particularly straight forward. I know it doesn't help you but the vast majority of customers wouldn't need to do this, you are one of a very small number of customers still using password authentication.
Please let us know how you get on
Vipersan
Message 9 of 20
Thanks Chris..
Hopefully this reply gets to you..
Found the router IP and navigated to the internet connection details..
Not exactly intuitive...and well buried under 'advanced' settings..
..but hopefully the real replacement router longevity connection test can now begin.
..as I am now using it with the modified details.
This whole process would not be easy for the average user...without a basic understanding of the process.
regards
Evan
Message 10 of 20
Hi Vipersan,
Yes it looks as though you'll need to enter the username and password in the router settings. The username is your full landline telephone number @talktalk.net and your can get your adsl password by calling 0345 1720 049 from your TalkTalk landline, you should get an automated message that will read back your password
Vipersan
Message 11 of 20
Yes ..I have received the replacement router Debbie....but I am currently back on my old one since the new one does not work for me.
I dont think the replacement is the problem.
It is the handshaking protocol I suspect.
Is the replacement designed to self install and connect ?
I connected it up as per the instructions.
The amber light flashes for a while but eventually turns white....but I cannot connect anything to the internet.
I left it in this state for at least an hour...but nothing changed..so
In order to get back here and report...I had to re-install my old router which went through its own start up procedure..but had me reconnected within minutes.
I do remember the engineer having similar issues when he came last time...whereby he had to manually enter some details in the old routers interface in order to get it to connect.
I suspect something similar here.
He was on the phone to talk talk in order to get those needed details and make the changes...and was perplexed that it wouldn't automatically connect.
I still had no clue as to why this is ?...but I strongly suspect a handshake issue...and do believe this relates to my unpredictable disconnection issues.
I cant prove this of course...but imo this is where ALL my ongoing issues lie.
There is a bug in your system that has never been corrected...and no fault at my location as confirmed by that engineer when he came many months ago.
It confused him and he is the professional...what chance would I as an end user have ?
regards
Evan
Message 12 of 20
Hi Evan
Message 13 of 20
Vipersan
Message 14 of 20
Many thanks Debbie...I will of course let you know with a reply to this thread.
rgds
Message 15 of 20
Hi Evan
Vipersan
Message 16 of 20
By all means...
I can certainly connect up a replacement to test.
Please make sure it has 4 LAN ports minimum...as I use a fixed cat5 wired system in my house..and dont use WiFi much at all.
cheers
Evan
Message 17 of 20
Ok thanks for confirming. Would you like us to send a replacement router for testing purposes to rule this out?
Vipersan
Message 18 of 20
Good Morning Michelle..
At least my connection remained intact overnight.
I use a landline phone and I hear no noise when using it....and no I am still using a black made by Huawei which you provided.
with five LEDs in a line horizontally and a power and reset button on the left side.
cheers.
I did have a larger silver one for a while but this one died some time ago...also provided by Talk Talk.
The last time all the problems occurred an engineer was sent to test everything ...and finally concluded the problem was not at my location...but at the exchange.
He resolved this problem I believe by routing to another exchange...I believe.
On this ocasion the connection intermittent problem became permanent eventually until he solved it....and hasa been fine since.
This was either late last year or earlier this year..
I forget.
rgds
Message 19 of 20
Good morning,
I'm sorry to hear this. The line test is clear. Can I just confirm, is there any noise on the voice service? Does your main socket have a test socket please? Do you also have an alternative router?
