Connection timed out
tubby885
Message 29 of 29
My router dashboard says my internet is on and my devices are connected but when I try to search,the progress bar reaches 10%ish and stops.
After about 10-15 secs I get a message saying connection timed out.
I've tried four different browsers and different devices without success.
Could it be my router settings?
I've had internet anout four weeks but can't use it . . .
K.Hall
28 REPLIES 28
Message 21 of 29
Perfect! @tubby885, I will need for you to double check if this matter only occurs on one device or is currently affecting all devices. Please confirm with feedback once done.
tubby885
Message 22 of 29
I'm home
K.Hall
Message 23 of 29
Not a problem, let me know when you are at home and we will proceed.
tubby885
Message 24 of 29
I will be at home at 11.00 hrs,thanks . . .
K.Hall
Message 25 of 29
Hi @tubby885 I will be able to run checks for you, are you at home to be able to proceed?
Message 26 of 29
Hi @tubby885 I really don't know but the team here should be able to do a whole bunch of checks for you to get you up and running.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
tubby885
Message 27 of 29
Hi @Divsec
My previous problem was that i was getting a message telling me to sign into my network and I couldn't sign in to my router[are these the same?].
Now I can sign in to my router which says i'm connected but still no internet with wifi or ethernet cable . . .
K.Hall
Divsec
Message 28 of 29
Hi @tubby885 your post has been escalated although it rather looks like a continuation of your earlier thread.
