on 28-07-2025 09:42 PM
My router dashboard says my internet is on and my devices are connected but when I try to search,the progress bar reaches 10%ish and stops.
After about 10-15 secs I get a message saying connection timed out.
I've tried four different browsers and different devices without success.
Could it be my router settings?
I've had internet anout four weeks but can't use it . . .
on 30-07-2025 08:35 AM
Hey there, @tubby885. I must apologize for the delay in solving your issue. Now @Gliwmaeden2 has clarified that you have connection but unable to connect successfully to a certain websit. We can try two things, but first I will need to know are you able to access another website?
I will need us to try and use these two things to help solve this.
Kanya
on 29-07-2025 10:45 PM
My devices and router dashboard say i'm connected butt when i attempt to access a website i get the connection timed out message.
No internet via ethernet or wifi . . .
on 29-07-2025 10:39 PM
I fear they probably will, just persevere.
And @Gliwmaeden2 I am not sure what you mean, you can connect a device by WiFi to router, but it is not much use if that in turn is not connecting to the internet?
on 29-07-2025 10:34 PM
Thanks for the advice.Talktalk recommend raising a complaint via chat so i'll do it tomorrow.
Just hope they don't ask me to go through all the checks again for the umpteenth time . . .
on 29-07-2025 10:27 PM
The diagnosis @KeithFrench reached in the previous thread was:
"Having done some diagnostics with @tubby885 I have cleared up all the confusion. The customer is connected to the WiFi network OK, but whenever a website is accessed in the browser, a connection timed out message is received. I have asked one of TalkTalk's support team to pick up your thread and investigate it for you."
Staff haven't made headway but if you are putting in a complaint, @tubby885, it's important to distinguish that there appears to be a connection but it's not been usable so far.
on 29-07-2025 10:22 PM
Will do . . .
on 29-07-2025 10:17 PM
OK and I am really sorry to see that things have been so bad. Let us know how you get on.
on 29-07-2025 10:14 PM
Thanks,I'll try that . . .
on 29-07-2025 10:12 PM
No internet at all? In which case I would go straight to the Complaints link at the bottom of the page.
on 29-07-2025 10:09 PM
The issue is that I have no internet with Talktalk.They've been "trying" to sort this for four weeks . . .
on 29-07-2025 10:06 PM
You can, but not until you have given them a reasonable time to resolve it. And personally, I am not at all clear what the issue is.
on 29-07-2025 09:44 PM
They gave up on me 10hrs ago.Their last message was a standard reply they send when they haven't got a clue what to do . . .
Can I leave Talktalk without a penalty because I'm paying for a service I'm not receiving?
on 29-07-2025 09:38 PM
They'll be back online tomorrow.
on 29-07-2025 09:26 PM
Looks like tech support have lost interest.
Does anyone have any ideas?
on 29-07-2025 11:55 AM
Is it the router settings?
on 29-07-2025 11:36 AM
I've done all those things.
Do I need a new router?
on 29-07-2025 11:31 AM
Reasons Your Internet Keeps timing out and How to Fix Them
- Placing your router in an open, central area allows the Wi-Fi signals to freely connect to devices. When you place your router in an enclosed space, the walls block those signals.
- Not every device needs to be connected to your home internet at all times, so be sure to disconnect unused devices for better connection.
- Upgrading your router and its software will show a noticeable improvement in how fast and reliable your internet connection can be.
on 29-07-2025 11:14 AM
Ok
on 29-07-2025 11:13 AM
I appreciate your prompt response.
I am currently looking into the matter and will keep you updated. Thank you for your patience.
on 29-07-2025 10:56 AM
It affects all devices
