on 09-03-2022 08:31 PM
Hello I have a DG8041W-2.T5 router
its new so I gave it 2 weeks to settle, then I gave another 2 weeks because of the storms, but it still not working.
i have done everything that is suggested on talktalk website but nothing is helping.
i am disabled and need wifi so i can access the camera at my door for my security.
telephoning Talktalk causes so much stress that I end up in tears.
many thanks for reading
on 10-03-2022 08:48 AM
Hi Jewels22
You're welcome 🙂
on 10-03-2022 08:47 AM
Thank you so much
on 10-03-2022 08:40 AM
Hi Jewels22
Thanks for the Private Message.
Let us know how the connection compares with the replacement router.
on 10-03-2022 08:18 AM
Hi Jewels22
Sorry for the delay. You should now be able to send me a Private Message.
on 10-03-2022 07:36 AM
Hi Jewels22
Apologies. I've just checked and I need to enable your PM's.
I will let you know as soon as they have been enabled.
on 10-03-2022 07:30 AM
Im struggling to send you a private message despite adding you as a friend
any suggestions how to?
on 10-03-2022 07:23 AM
Hi Jewels22
Yes no problem. Please can you send me a Private Message to confirm your address.
on 10-03-2022 07:21 AM
Yes i would appreciate that so much
just check that you have my correct address because the first router was sent to my previous address
thank you so much
on 10-03-2022 07:18 AM
Hi Jewels22
I can send you a replacement router for testing, would you like me to arrange this?
on 10-03-2022 07:15 AM
Yes I’ve rebooted the router several times
ive tested the line myself and it appears fine.
since we had talktalk installed there has always been an issue but i thought it was because for the first 2 weeks it takes time to settle, then the storms, but now it is worse than it was.
my daughter is unable to revise for exams because wifi connection to our mobile telephones and youtube etc doesn’t work
could the router be faulty perhaps?
thank you
on 10-03-2022 07:06 AM
Hi Jewels22
Thank you.
The line test is clear and your line is showing in sync and connected.
What happens when you try to connect? Have you rebooted the router?
on 10-03-2022 06:58 AM
Hello Debbie
i have added my landline number in notes on my personal information
thank you
on 10-03-2022 06:24 AM
Hi Jewels22
Please can you add your TalkTalk landline number to your Community Profile, we can then take a look at this for you.
on 10-03-2022 06:23 AM
Hello
thank you for replying
the white light stays on
Wifi isn’t working on mine and my daughter’s phone at all.
unable to watch netflix etc because no connection
No wired connections on anything because we rely on wifi
I hope that’s answered everything
thank you
on 09-03-2022 10:09 PM
Hi @Jewels22,
Can you explain exactly what problem you are having ?
If your connection is dropping do you know if the problem is with the router losing its connection to the internet (in which case a light on your router which is normally constantly lit will change colour or flash), or is it that you are losing Wi-Fi connection between your device(s) and your router (in which case the light(s) on the router will just carry on looking normal).
Do you have any ‘wired’ devices, do they also lose connection ?
The TalkTalk Support Team on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
