Devices lose WiFi often
JensLondon
Message 7 of 7
My broadband connection works fine in principle.
However, my connected devices sometimes a few times a day stop receiving data from the router via WiFi.
What I then have to do is turn WiFi off not he device, and turn it back on, so that a fresh connection to the router is established.
Surely that can't be right.
How do I even go about getting help for this problem? The router is 4 years old if that matters, and it is the standard TalkTalk router.
6 REPLIES 6
Message 1 of 7
I have received one screenshot from NetSpot from @JensLondon , which means I still need to see the complete set, namely:-
  1. Networks around you (AP view) – please ensure that all networks are selected and that all of your SSIDs are shown in the window. Make use of sorting the SSID column, the vertical scrollbar to achieve this. If you have any Wi-Fi extenders, or printers broadcasting networks, then I need to see these as well.
  2. Signal strength graph – please highlight one network per band in the AP list first. Let this run for 5 mins before taking each screenshot.
  3. Channels 2.4GHz – please highlight each network in the 2.4GHz band in the AP list and then take as many screenshots as you have networks in this band.
  4. Channels 5GHz – please highlight each network in the 5GHz band in the AP list and then take as many screenshots as you have networks in this band.
I also need to know your SSID (network name).
Message 2 of 7
Hi @JensLondon
Do not worry about interpreting the results, I will do that for you. I will send a PM to you that contains a link for a guide of mine on Wi-Fi interference. It is quite long (about 30 pages), but you will probably only need to look at three or four pages in total. Initially look at the section called "Are you suffering from interference – prove it first". This is the first link in the table of contents. This section includes full details of free Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Select the analyser of your choice & my guide explains how to use it.
If you are using Wi-Fi Scanner, then please attach the zip file to this thread. As soon as I have downloaded it, I will remove the attachment from your post, to preserve your privacy.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please as they can be difficult to read, because the text can get out of focus when zoomed in. Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large.
Message 3 of 7
Thanks it runs on 5 GHz
Message 4 of 7
Thanks, it's a Sagemcom router.
It is true that I never had this problem the first two years or so, and since then it has become worse and worse.
Message 5 of 7
Gliwmaeden2
Message 6 of 7
There have been both Sagemcom routers and Huawei ones in the past 4 years.
Check the very small print on the label stuck under the area where you can retrieve the password etc for the make.
The Huawei one is not receiving updates and is no longer issued.
Staff will be back after the weekend.
Ensure that your profile information is filled with the Talktalk landline telephone number or account number. Go via your avatar; settings etc to access the profile area. SAVE CHANGES.
