Disable UPNP
blackline842
Message 6 of 6
Hi, can I get an admin to disable the UPNP setting on my router, thank you.
5 REPLIES 5
Message 1 of 6
Hi blackline842
This has now been disabled as requested.
Message 2 of 6
Hi Debbie, yes it was off. It is now back on, thank you 🙂
Message 3 of 6
Hi blackline842
Is your router switched off at the moment?
Message 4 of 6
Thanks! I have done so 🙂
Skynet_TX
Message 5 of 6
Hi @blackline842,
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk staff on this community can see your profile details).
