Disabling WIFI Optimisation
Spire
Message 5 of 5
Hello, I would like to be able to manually set the channels without them reverting. Therefore, could I ask that WIFI optimisation on my router be turned off?
Thank you.
4 REPLIES 4
Message 1 of 5
Spire
Message 2 of 5
@Divsec @Chris-TalkTalk Thank you.
Chris-TalkTalk
Message 3 of 5
Hi Spire,
I've disabled wifi optimisation as requested
Divsec
Message 4 of 5
Hi @Spire your post has been escalated and you should hear tomorrow. Please remember that every time you reset your router to factory defaults or the firmware is updated you will likely need to repeat this request.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
