ETHERNET CONNECTION BUT NO WIFI
jinakolis
Message 2 of 2
My set up - Ethernet Connection to Desktop. WIFi for other services Tablets, TV, Printer etc. Problem- I am able to connect my desktop to the internet via Ethernet(which I am using now). I have no WiFi connection and no availability showing on Tablet. History - I connected a printer to the WiFi network, the connection was made ok but WiFi was lost straight after this. Router Status - On pressing the power on button orange light blinks for a while then turns off. I realise this is not a service problem but any suggestions very welcome.
1 REPLY 1
Message 1 of 2
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
Anonymous User
