Eero instead of my existing modem
AndyUK2
Message 3 of 3
Replace my existing modem for eero
Message 1 of 3
Hi AndyUK2
Which package do you currently have? As Keith has advised, the eero is only provided on Full Fibre 150 or faster packages.
Are you experiencing issues with your current router?
Message 2 of 3
The eero is only available on the Full Fibre 150 or faster packages.
