Faulty Router
ElviK
Message 4 of 4
HI there
It seems the last couple of.month, my router has started having difficulties keepn i ternet up. I have a very good speed to the router by my internet at speed test is poor( good on router) .
Need to restart router every 10-20 min to be able to get a good speed but this last just minutest and it drops.down again.
Is any chance i can get a replacement router, or whom do i have to contact to get one.
Thank you
Elvi Kolai
3 REPLIES 3
Message 1 of 4
Hi ElviK,
Do you still need assistance with this?
Message 2 of 4
Hi @ElviK
Is this also affected wired connections?
Message 3 of 4
If the speed to the router is good but the speed from the device is poor, it is probably not the router unless it affects Ethernet-connected devices. What sort of devices are poor, Wi-Fi-connected ones, Ethernet or both?
