on 13-01-2022 02:10 PM
I don't understand why I can't be sent a new router? Two discussions with tech support has made me feel like I'm dealing with some very un-technical people.
I have a new router at my new home on my new contract.
5ghz AC/ax connections work fine
2.4 GHz a/b/n connections can't see a network ID.
Tried giving the 2.4ghz band a different name. Fixed channel number, fixed 20hz bandwidth. Nothing helps.
A network scanner shows no broadcast ID on the 2.4ghz band.
But default all settings and leave the router off for 5 minutes, turn it on again. then router the ID appears for about 2 minutes at a very low dB level and then just vanishes.
I take it that the chipset is warming up and then just cuts completely or an internal aerial is loose.
So explaining this to technical support turns into a barrage of having to call while at home and run through a bunch of pointless tests. I'm not at home before 8pm and out the house by 7am.
How do I get a new router? As this one is DOA. Or do I just cancel my service?
on 18-01-2022 09:13 AM
That's great news, thanks for letting us know.
on 17-01-2022 06:23 PM
New router arrived and it all works great. Many thanks.
on 13-01-2022 02:30 PM
Hi Tom
Thanks for updating your Community Profile 🙂
on 13-01-2022 02:25 PM
That's a great reply, details added. Thank you 👍
on 13-01-2022 02:14 PM
Hi Tompringle
Please can you add your name and TalkTalk landline number to your Community Profile. I can then send you a replacement router.
