Finer details
Goldie42
Message 2 of 2
I am thinking of maybe investing in Sky Glass but know it needs an appropriate broadband service.
Currently I have Fibre 35 with you.
I was thinking I may need to upgrade, but I need to check a few things first that I cannot find on your website...
Given that I will be streaming video almost 100% of the time and some may well be in HD I wondered what the minimum spec service you would recommend would be. I also need to be sure there is no data cap as I know this amount of streaming will take a LOT of data.
I am also interested if you apply any throttling should the data usage exceed certain limits. Of course if I am streaming all my TV services, I do not want to find that at a certain point the service drops.
Also do you offer any guaranteed speeds or are they just quoted as averages?
Colin.
1 REPLY 1
Gliwmaeden2
Message 1 of 2
The specifics of your speeds for the account you are on are detailed in Service Centre, @Goldie42.
Your speed won't be throttled and data download is unlimited (but subject to fair usage).
Read the Ts&Cs, linked at the foot of any TT page.
For any new service / renewal  / upgrade you would need to get specific details by phoning up:
03451 720088 after 9am.
