Firmware Update SG4K10001400t
on 02-07-2022 04:57 PM
Message 15 of 15
Can I request that the firmware on my TalkTalk Router is updated to the latest version it is currently running versions below which I think is from 2017
Hardware VersionSoftware VersionGUI Version
FAST5364 3.00 |
SG4K10001400t |
1.152.6 |
I have been using my own router since moving to talktalk but want to use the standard kit and would like the latest firmware
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
14 REPLIES 14
on 05-07-2022 11:24 AM
Message 1 of 15
I've ordered the router now Jason and they generally arrive within a couple of working days but most seem to arrive next day so you will probably receive it tomorrow. Unfortunately I can't guarantee that it will have the latest firmware, they usually need updating but this usually happens automatically within the first 24-48 hours after it's connected
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-07-2022 11:17 AM
Message 2 of 15
Thanks Chris
do you know how long it will take? Also will it come pre-loaded with latest fw so I don’t have to through this process again?
I will see if I can resurrect an old cable modem to get me running until the new one arrives
thanks
jason
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-07-2022 11:00 AM
Message 3 of 15
I'm sorry about this but if the router still isn't working then it looks as though it's bricked and will need to be replaced, I'll order a replacement now, apologies for any inconvenience
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-07-2022 10:50 AM
Message 4 of 15
Tried a reset on the router 2 times the light just constantly flashes red and doesn’t go out or reboot also tried holding reset while powering on the router same result the router light just flashes red constantly and no access to internal network even with a static ip in the network range 192.168.1.x looks like it’s broken
what is the next steps as I am without internet when working from home
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-07-2022 10:43 AM
Message 5 of 15
Could you try resetting you router to factory default settings and then retest - (1) Restore your router to factory settings - TalkTalk Help & Support
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-07-2022 10:33 AM
Message 6 of 15
Rebooted a couple of times just get a red flashing light on the front and no dhcp for internal network tried direct with Ethernet and the WiFi ssid for the router isn’t seen at all I can’t post the video of the router as the site won’t allow .mov files and can’t zip on iphone
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-07-2022 10:23 AM
Message 7 of 15
Yes, could you try a reboot, the firmware update should have completed by now
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-07-2022 10:03 AM
Message 8 of 15
Hi chris
the router light is flashing red and has been doing so for 20 minutes should I attempt a reboot. Also I have no internal IP address on dhcp from any device
thanks
jason
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-07-2022 09:32 AM
Message 9 of 15
The upgrade should complete in a few minutes 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 05-07-2022 09:24 AM
Message 10 of 15
OK, no problem, I'll start the upgrade now, it can take up to 20 minutes, please don't switch off your router
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-07-2022 08:27 PM
Message 11 of 15
Unfortunately I didnt get a notification of your message - can this be performed 05/07/22 any time in the morning
Jason
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 04-07-2022 07:44 AM
Message 12 of 15
Hi Jason,
I can update your firmware, would you like me to do it now, it can take up to 20 minutes to complete?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 03-07-2022 12:06 PM
Message 13 of 15
Thanks for the info - I have added details to my profile and will see if it has updated in a few days
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 02-07-2022 09:53 PM
Message 14 of 15
Hi @jason-burke1980,
If you have only just connected this router up then you will probably find that it will upgrade itself automatically overnight within a few nights. However the support team here on the community can also push a firmware upgrade out manually if required.
For one of the TalkTalk Support Team on this community to be able to look into this you will need to update your community profile to include your name, landline telephone number that your TalkTalk service is provided on & an alternative contact number. This will allow them to identify you, and they will then be able to help.
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk Support Team on this community can see your profile details).
They won't be around now until Monday, but they should be able to respond to this post early next week to help.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
