Firmware update needed?
firepit
Message 19 of 19
I'm experiencing what appears to be a known TT problem, in that I cannot add any port forwarding nor can I make any firewall port changes.  I'm trying to see internal CCTV from the Internet"  This was working before I upgraded to the new Sagecom FAST5364 3.00  (Software SG4K100136)  When ever I try to add a rule or make a change I get an error message "something wrong happened"
I've seen a few other mentions that this may be a known problem if your network is setup as something like 192.168.0.1 - 254  which mine is!!   because have have a second router with a network using 192.168.1.1 already.   (configured from the TT modem via cable to the WAN port of an ASUS router)
https://community.talktalk.co.uk/t5/Broadband/Fast-5364-port-forwarding-error/td-p/2627018
So does anyone know if this is fixed in a new firmware release?  Or should I change the ip ranges around so  the TT has 1.1 and the Asus uses 0.1??  Would that work.
Cheers,
Paul.
18 REPLIES 18
Message 1 of 19
I'm really glad to hear this and thanks for confirming 🙂
Message 2 of 19
Hi Debbie, I have got it all working now, so I can see my cctv externally as before.
I can't say whether the firmware upgrade was absolutely needed along with the "factory reset" back to the default 1.1 network config or not, because we did the update first and it didn't solve the problem on its own.
Many thanks for the teams assistance.
Paul.
Message 3 of 19
Hi Paul
Message 4 of 19
I’ve managed to get it reset and my network all reconnected.
I can now make additions to the port forwarding and firewall settings which stick without error messages.
tomorrow I’ll check if that functionality is actually working.
cheers,
paul.
Message 5 of 19
Ok thank you 🙂
Message 6 of 19
Ok I will give that a go.  I'll let you know when I am done.
Message 7 of 19
OK could you try resetting the router to factory default settings and let us know how you get on
Message 8 of 19
Rebooted and retried but I am still getting exactly  the same messages
Message 9 of 19
Could you try rebooting the router and then retest
Message 10 of 19
It's stopping me from making any network changes whatsoever.  So here I tried to set a Pi as a DMZ but that also fails.
Message 11 of 19
Thanks Chris.  I can now see the new firmware number.  However the original issue is still there in that I cannot add a port forward rule.
Message 12 of 19
Yes, the firmware is now updated 🙂
Message 13 of 19
Hi Chris, were you able to do it?
Message 14 of 19
OK, I'll update your firmware now, please don't switch off your router
Message 15 of 19
yes that's good, please go ahead.
Message 16 of 19
Yes, we can update your firmware now if you like, is this OK?
Message 17 of 19
Hi Debbie, Much appreciated.    You can do it anytime as it is permanently on.
Will you be able to do it today?
Message 18 of 19
Hi Paul
I'm not sure if this fix is included but I can update the firmware for you. When would be the best time to do this?
We advise to leave the router switched on without being rebooted whilst we update the FW.
