Glitches with Zoom
gjc26
Chat Champion
Message 111 of 111
So I've been having glitches with Zoom.
OpenReach came in and tweaked things, which brought my connection speed up from about 55mbps to just under 80mbps, but the drop outs and "your internet connection is unstable" issues persist.
I prefer to use my own router, it's a Netgear.
I wonder if there's a setup issue, here are the current settings:
Select Country: UK
Select Internet Service Provider: TalkTalk
Transfer Mode: VDSL (PTM)
DSL Mode: VDSL 2
Multiplexing Method: LLC-BASED
VPI: 8
VCI: 35
Use VLANID: 101
Priority(0~7): 0
MTU: 1500
IGMP Proxying [not disabled]
Support British Telecom (BT) IGMP Proxying [doesn't matter if enabled or disabled still glitches]
Disable SIP ALG [doesn't matter if enabled or disabled still glitches]
I think these are the key ones.
Are these correct, and any more suggestions?
110 REPLIES 110
Message 21 of 111
Hi gjc26
Is the Sagemcom hub connected at the moment?
Message 22 of 111
I received the router and have set it up (UPNP is off).
I can plug this in tomorrow am (about 6:30am) so that you can do the firmware rollback (this one is on SG4K100136).
If you are doing that, I think that that version is negatively impacted by WIFI optimisation; are you able to turn that off whilst / after doing the rollback?
Many thanks.
Message 23 of 111
Hi gjc26
The Sagemcom hub is on its way, please allow 24-48hrs for this to arrive.
Message 24 of 111
Hi, nothing was connected to the WAN.
I tried it a few more times, still a flashing orange light, so I think that sending out a new one is a good idea (Sagemcom again, the speed seemed much better).
I've plugged the Huawei back in for now to give me a connection, hotspotting's a bit unreliable.
Message 25 of 111
Hi gjc26
Can I just check, do you have anything connected to the WAN port?
Message 26 of 111
Hi gjc26
I still can't connect to your router, I'm really sorry about this.
I will need to send you a replacement router, will it be ok for me to arrange this?
Message 27 of 111
Still flashing orange.
Message 28 of 111
Hi I’ve just done that.
Message 29 of 111
Hi gjc26y
Apologies I'm still unable to connect to your router.
Could you try a factory reset (pin hole reset for ten seconds)
Message 30 of 111
Done.
Message 31 of 111
Hi gjc26
Sorry, please can you switch off at the wall for ten seconds and then switch back on.
Message 32 of 111
Or just turn it off and back on again with the switch…
Message 33 of 111
When you say reboot, reset on the back or plug in Ethernet and from the menu?
Message 34 of 111
Hi gjc26
Apologies for this. Please can you reboot the router for me?
Message 35 of 111
Hi. I’m not on WIFI currently. The router went from white to orange a little earlier, it’s now flashing orange.
Message 36 of 111
Hi gjc26
I have made a change to your router firmware, is the router switched on at the moment?
Message 37 of 111
Just a quick side flag that on the Service Status page (https://www.talktalk.co.uk/help/servicestatus/), they seem to have changed the Speed Test to a progress bar (https://www.talktalk.co.uk/help/servicestatus/speed-to-router😞
Sit back and relax whilst we check your speed...
Your devices need to be connected to your TalkTalk home network via WiFi.
Loading...
Then it gives:
Speed to router
Great! You're getting the download speed of 72 Mbps, as expected
Your guaranteed speed: 55 Mbps
And also:
Speed to devices
Some of your devices may be facing issues
We've checked everything on our side and there are no issues with your line. There appears to be an issue between our router and some of your device(s).
Further down the speed to devices page, it gives the mac addresses of my connected devices and measured speeds (which seems a little intrusive, shall we say); not sure about the accuracy of this latter test, as it's way off the figures I get when running speed tests from individual devices.
The old speed check still seems to be available at, but it's not linked in the same way as before:
https://www.talktalk.co.uk/speedcheck/
Is this because I've changed router or is that a change that came in today to the Service Centre, totally coincidentally?
Message 38 of 111
Hi, yes, that would be fine too. Thanks.
Message 39 of 111
Apologies, unfortunately we won't be around then to complete this. Would it be ok if we did it tomorrow morning between 6.30-7.30?
Message 40 of 111
Hi. So probably about 5:35/5:40pm today would work for me, assuming it doesn't take forever.
If you do that, are you able to also turn off the Optimisation at the same time?
