How to put router into modem mode
ttlwl
Message 4 of 4
I am using talktalk DG8041W (EchoLife DG8041W Home Gateway) router, with:
Hardware Version: I.1.01
Software Version: v1.05t
How do i set this router into modem mode? Like Virgin Media has this option. does the above router has a similar feature?
3 REPLIES 3
Message 1 of 4
Double NAT, depending on your Virgin router does work well.
Message 2 of 4
Ok, thank you. The double NATs would be an issue, so I will keep it unchanged.
Message 3 of 4
You can't. Although I can provide a suitable workaround, but it does introduce double NAT.
