How to track a reported fault
IdontBelieveIt
Message 16 of 16
How do I track a reported fault?
I'm on my mobile bcos my land-line and broadband were cut off an hour ago.
It was a nightmare finding the page to report a fault but once done the page gave the instruction to "do not leave this page or the fault tracking will fail". It then logged me out due to inactivity...
Thankfully I made a screenshot with the fault ID but now I can only find the pages to report a fault even though the search gives "Report & track a fault".
Rgds
Stephen Ford
AkrutoSync MS Exchange emulator to sync Win10 Outlook (2010) to Android.
Router: ADSL (TP-Link Archer VR600)
PRT: HP 8210
15 REPLIES 15
Message 1 of 16
Sorry, I don't know. There are no further updates at the moment but I'll check again later
Message 2 of 16
How many other households in my area have this outage?
Rgds
Stephen Ford
PRT: HP 8210
Message 3 of 16
Openreach will never talk directly to a customer and refer you to your provider.  the reference number is an internal number for the Openreach system Only and a TalkTalk employee can access this specific reference.  You would not be able to use the reference.
Message 4 of 16
What is the Openreach reference for this fault?
Rgds
Stephen Ford
PRT: HP 8210
Message 5 of 16
This was assigned to an engineer earlier today and appears to have now been linked to a major service outage. I'll check for further updates later today
Message 6 of 16
Rgds
Stephen Ford
PRT: HP 8210
Message 7 of 16
Hi Debbie
This is dragging on a bit now. It's the fourth day without a landline. And I'm in tenterhooks as to the next time I will lose screen input like this message when broadband fails. I'm always copying the text just in case the page closes.
How to I check fault status please? I was told below to use the Dashboard, but apart from struggling to find the Dashboard (there is no title on the page), and then when I realised it was the first page on login, I found there is no mention of fault tracking.
I tried the help system and no mention there either.
Rgds
Stephen Ford
PRT: HP 8210
Message 8 of 16
Hi IdontBelieveIt
This fault is still with the Openreach line engineers. I will continue to monitor for updates and I will post back on this thread as soon as I receive further information.
Message 9 of 16
Not possible on a Bank Holiday, @IdontBelieveIt.
Message 10 of 16
I have been struggling to find things on the TT website.
I was trying to find the "Dashboard" and by luck, found a drop-down with a link to the Dashboard. Then I realised that the first page after login is indeed the Dashboard.
How would a new user know that the Dashboard page is just that if he didn't notice the link in the drop-down?
I have been using the site since good old Openreach brought down my landline and made my broadband almost unusable on the 24th August and only discovered what the Dashboard is today - hidden in plain sight you might say...
You say that updates "may appear"; there is nothing on my Dashboard about fault tracking - is there nowhere else I can track the fault ?
Would you ask Openreach for an update please. My landline has been out for three days and since then broadband barely works.
Rgds
Stephen Ford
PRT: HP 8210
Message 11 of 16
If any updates are sent to our systems from Openreach they may appear within your dashboard under the option to track a fault, but more often we may need to request an update from Openreach as we have access to their system.
IdontBelieveIt
Message 12 of 16
Ok, Thanks.
So how do I track a reported fault?
If I search for "track fault" it finds "Report & track a fault". That link takes me to a page where there is no occurrence of the work "track" on the page. There is only "report".
Rgds
Stephen Ford
PRT: HP 8210
Message 13 of 16
A Fault has been logged to Openreach however there are no updates as yet.  This will be delayed because of the Bank Holiday and we can re-check tomorrow.
IdontBelieveIt
Message 14 of 16
Hi Debbie
I have updated my Profile as requested. Anything missing, please let me know.
Rgds
Stephen Ford
PRT: HP 8210
Message 15 of 16
Hi IdontBelieveIt
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
