Huawei router, WiFi signal failing
Skint
Message 8 of 8
Hello all,
Any thoughts on boosting the WiFi signal on the Huawei router?
It seems to have degraded, it is not next to a magnetic source. The router has not moved but is getting excessively hot. Tried turn off cool down but to no avail.
7 REPLIES 7
Message 1 of 8
Hi Skint
That's great, thanks for letting us know 🙂
Message 2 of 8
Debbie,
Yes this morning. I have installed all is A-OK, i think that the old router may have been burning out (had this before with a netgear). I think it was 3yrs old on 24/7
Thanks for sending the new router, i have packaged and just sent the old one back.
Best regards
Message 3 of 8
Hi Skint
Message 4 of 8
Hi Skint
Message 5 of 8
Michelle,
That would be brilliant and thanks Keith.
Message 6 of 8
I'm sorry to hear this. We can send a replacement router for testing purposes and a router returns bag so that the original router can be returned. Would this be ok?
Message 7 of 8
Is it well ventilated as it will probably run warm, but not hot? I think in light of this, the first thing to do is to get it replaced. I have asked one of TalkTalk's support to pick your thread up and replace it if they agree with me. However, this may well not improve the wireless strength, as I suspect that is a separate issue. When you get the replacement, unless it is all working fine, let me know & I can help a lot with Wi-Fi issues.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
