Inconsistent and high latency
simhub1985
Message 9 of 9
I need some help please with ping that regularly spikes to about 200ms and will sometimes stay like that for hours.  At other times it's more like 30ms and stable.  The issue seems to be with the first hope from my house to TalkTalk.  Is there anything you can do to diagnose this please?
Simon
8 REPLIES 8
Message 1 of 9
Thank you. I've run a test on the line now which is clear. I can see from your post above that this also happens if you connect wired at the ONT, is this right? Does it seem to happen at certain times of the day? If you run a speed test when the latency increases, are the speed also low?
Message 2 of 9
Thank you Keith
Message 3 of 9
  • Name
  • Telephone number
  • Alternative contact number
Message 4 of 9
To save yourself time, please make sure that your community profile includes your first & last names, Full Fibre account number & if you can, please include the serial number from your ONT in the Private Notes section. Please also try to include an alternative contact number. This can be done by clicking on your Avatar picture then click on "My Settings" followed by:-
Message 5 of 9
It's the same I'm afraid, brief periods when ping is about 5ms but mostly unstable and over 100ms.
Message 6 of 9
Assuming the 150M service is over full fibre, what is it like if you connect the PC directly to the ONT, in place of the router?
simhub1985
Message 7 of 9
Hi Keith
This is on a PC with ethernet to the router.  I have Fibre 150.
Message 8 of 9
Are these on wired (Ethernet) or Wi-Fi connected devices? If the latter, which Wi-Fi band are they using, the 2.4 or 5GHz?
What package are you on?
