ROUTER Sagemcom Fast 5464 and setting of Firewall.
Billx
Enlightened One
Message 47 of 47
I would like a newer version of the router firmware and the manual of the router. Usually this is done from the manufacturer. The manufacturer does not have any portal for firmware or manuals. Do you as the ISP have a portal to download new firmware and the manual?
Navigating within the router, there seem to be various faults. I am unable to set the firewall, as it doesn't offer the options required. There are various odd things appearing in the log within the router. I've read some of the posts in the community, and it seems it might be a good idea to disable wireless optimization. Some posts suggest that TalkTalk  are the only ones able to upload any firmware or disable wireless optimization. Does TalkTalk repeatedly monitor and download all my settings? I am not sure what's going on.
46 REPLIES 46
Message 1 of 47
@Ljmm1967, see this article:
https://community.talktalk.co.uk/t5/Articles/Set-up-a-non-TalkTalk-router/ta-p/2205383
If you need further help, please start your own thread. Staff only reply to the original poster.
Ljmm1967
Message 2 of 47
You can use your own SSH Client I.e PuTTy, but you will need to know what your doing. My son is a network engineer for another ISP and explained how to use SSH. I haven’t done it, as my router isn’t currently broadcasting due to a fault within. I’m currently waiting for a replacement. If that fails I’ll be configing my own. @Chris-TalkTalk where can I find TalkTalk’s router configuration details, if I need to use my own router/modem.
Message 3 of 47
It's my understanding that it monitors to provide diagnostic information but I don't know specifically.  I'll ask our product team if they can provide any more information
Message 4 of 47
Hi, @Chris-TalkTalk,
Agreed, it's not checking the firmware, because that's just been updated.
So what data does it keep taking from me, that it does not know already?
Bill
Message 5 of 47
Hi Bill,
I don't know exactly what it checks but it does check more than just the firmware
Billx
Enlightened One
Message 6 of 47
Hi @Debbie-TalkTalk
Please read my post on 23/6/2023.
Once the firmware has already been updated, what is your ACS server trying to check,
and what information is it downloading?
I've asked the question before in different words, but you keep swerving from answering the question I am asking.
Bill
Message 7 of 47
Hi @Debbie-TalkTalk
Well yes, exactly, why would someone re-update something which has just been reupdated? Obviously.
But that's not the point, your ACS server and the router keep connecting each other, at least twice a day, as recorded in the logs below.
23.06.2023 13:55:46 Info SYS TR-069 connectivity to (acs.talktalk.co.uk) has been closed
23.06.2023 13:55:44 Info SYS TR-069 connectivity to (acs.talktalk.co.uk) has been initiated
23.06.2023 06:38:23 Info SYS TR-069 connectivity to (acs.talktalk.co.uk) has been closed
23.06.2023 06:37:55 Info SYS TR-069 connectivity to (acs.talktalk.co.uk) has been initiated
22.06.2023 17:51:14 Info SYS TR-069 connectivity to (acs.talktalk.co.uk) has been closed
22.06.2023 17:51:14 Info SYS TR-069 connectivity to (acs.talktalk.co.uk) has been initiated
22.06.2023 13:55:46 Info SYS TR-069 connectivity to (acs.talktalk.co.uk) has been closed
22.06.2023 13:55:44 Info SYS TR-069 connectivity to (acs.talktalk.co.uk) has been initiated
Once the firmware has already been updated, what is your server trying to check,
Message 8 of 47
Hi Billx
Do you mean when new firmware is updated?
This is only pushed out (once) when new firmware is available. This is not a daily event. The system will check which firmware version your router has and when new firmware is available then this will be remotely updated by TalkTalk, this usually happens out of hours.
Message 9 of 47
It is probably just a stock page transposed from standard router information into TalkTalk where, as you have been told, it does not apply. Mildly irritating at worst, but surely not so much when you have had it explained to you?
Billx
Enlightened One
Message 10 of 47
Also, @Chris-TalkTalk, does TalkTalk have to update the customers routers daily or more often, and what information does TalkTalk take, each time it updates?
Message 11 of 47
@Chris-TalkTalk ,
Please view what I have in 5464 version SG4K100174
This obviously does not tie in with automatic updating by TalkTalk ISP.
To have automatic updating by TalkTalk ISP, then this setup screen must be DELETED.
Using 'Update' on this screen will do absolutely nothing.
Also, read the 3 steps recommended by the TalkTalk router on the above screen.
Does TalkTalk like just putting nonsense, in their router?
Bill
Message 12 of 47
Hi Bill,
Just to confirm, as Keith and Gliwmaeden2 have been saying, the router firmware is updated remotely by ourselves, there is no option for the customer to do this themselves. Also 174 is the latest firmware and it's the same firmware for both the wifi hub 1 and wifi hub 2 (5363 and 5464). Apologies for any confusion
Message 13 of 47
I have requested that TalkTalk post on this thread @Billx to confirm what we have been trying to tell you.
Message 14 of 47
Yes @Billx
I realise that you have the 5464 & not the 5364, they are both the same in this respect. It is totally beyond mine or @Gliwmaeden2 control. However, I will pass on your comments to TalkTalk.
Message 15 of 47
Hi @KeithFrench ,@Gliwmaeden2
To have automatic updating by TalkTalk ISP, then this setup screen must be deleted.
Please advise Central office to delete it.
Or give me a contact to advise them myself.
Sorry to go on and on, but this is getting beyond a joke.
Bill
Message 16 of 47
Yes, I just noticed that too. That is the right option. Thanks again.
Message 17 of 47
There's a "browse files to attach" option below the message box, @Billx.
But the point is that, whatever you send, it's not always compatible at the receivers' end, whereas the images are immediately accessible to anybody.
Message 18 of 47
Yes, I know how to copy a picture into the post. I also was able to attach a file previously, but I have forgotten how to do that. Thanks for now
Bill
Message 19 of 47
I've seen people attach files, but they can't always be opened to read here, @Billx.
More reliable is to take a screenshot of important stuff and load it to the message using the camera or icon function (depends which device you are using). Image icon in message box:
I just take screenshots and use the image icon. Click on it then the  selected image and it loads into the message that you are posting. Then post in the usual way in your thread.
Message 20 of 47
Thanks, @Gliwmaeden2, Can you please tell me how to do something? I want to attach a text file to a post. Can I do that?
