Internet Connection Keeps Dropping
nickr
Message 43 of 43
Can anyone here help with a problem that I've been having recently with a dropping broadband connection. Over the last few days the connection has started to drop every few minutes, sometimes it lasts a bit longer, but it's off more than it's on just recently. I have run a TalkTalk Health Check and the report says there is a problem with my line. The router (DG8041W) is currently hard wired to my pc with an ethernet cable to eliminate a wifi problem, although I'm pretty sure it's not wifi because the white light on the router (DG8041W) goes red when the connection drops. Thanks in advance. Nick.
42 REPLIES 42
nickr
Message 41 of 43
Thanks for the response. I'll connect to the test socket and report back. 👍
Message 42 of 43
I'm sorry to hear this. I've run a test on the line now which has detected a potential loop fault which can sometimes be caused by internal wiring or equipment connected to the line. Does your main socket have a test socket please?
