Internet Connection Keeps Dropping
nickr
Message 43 of 43
Can anyone here help with a problem that I've been having recently with a dropping broadband connection. Over the last few days the connection has started to drop every few minutes, sometimes it lasts a bit longer, but it's off more than it's on just recently. I have run a TalkTalk Health Check and the report says there is a problem with my line. The router (DG8041W) is currently hard wired to my pc with an ethernet cable to eliminate a wifi problem, although I'm pretty sure it's not wifi because the white light on the router (DG8041W) goes red when the connection drops. Thanks in advance. Nick.
42 REPLIES 42
Message 1 of 43
Hi Nick,
Line test is failing and can see the speeds are low and connection is very unstable. I've raised this to Openreach for further investigation
nickr
Message 2 of 43
And another one. Done within moments of the last one. Internet speed changing by the minute.
nickr
Message 3 of 43
Another test done moments after the other test.
nickr
Message 4 of 43
Results of my internet speed test from 2 minutes ago.
Message 5 of 43
I had no choice and it certainly wasn't something that I wanted to do. I had to drive 15 miles each way the night before the exam after work to get it all set up and then the 15 miles each way the next day to sit the exam.
I received the message that I posted earlier from TalkTalk the weekend before acknowledging that there was a problem with my line and that an Openreach engineer would dealing with the problem and they would contact me with an update. That was 18th of November. Has anyone contacted me?? No prizes for guessing the right answer. 🤥
Message 6 of 43
I'll re-escalate this thread, @nickr.
Glad to hear that you made the contingency plans last month!
nickr
Message 7 of 43
My connection started dropping again yesterday. Can I get an update on this message that I received from TalkTalk please. Nobody ever got back to me as promised in the message, so I'm none the wiser as to whether anything ever got fixed or not. I had to use SOMEBODY else's internet for my exam a few weeks back. (FYI) Thanks in advance.
Message 8 of 43
Hi Nick,
I've sent a PM with another link
Message 9 of 43
That is the snag with the whole online exam culture, @nickr.
There can be a problem with your connection and / or device any time, of course, so all you can do is mitigate the situation. If there's any likelihood of problems not being sorted in time, can you make contingency plans to sit the exam in a different location?
Any PMs sent by staff need a reply the very same day, as the link expires. Another one will have to be sent.
nickr
Message 10 of 43
I have an online exam on Friday and if my connection drops during the exam, I'm pretty much screwed. I received a text message from talktalk saying that they acknowledge a problem between the exchange and my address and that they were sending an Openreach engineer to fix it within 2-3 working days. The 3rd day will be tomorrow. Apparently Openreach will be in touch with me directly with an update. Chris..... that link that you sent me isn't working. Thanks in advance for your help. Nick.
Message 11 of 43
Hi nickr,
I've sent you a PM to confirm some details so that we can discuss the issue further
Message 12 of 43
You will have to wait until Monday for a further response from the support team. If there is a fault with external wiring then TalkTalk can arrange an engineer.
nickr
Message 13 of 43
I have no choice but to search for another ISP. Connection dropping every 2 minutes. It has to be the wires outside property. This is ridiculous. 😒
nickr
Message 14 of 43
Message 15 of 43
No...just 4 copper wire.
Message 16 of 43
Hi nick
Can I just check, do you have a FTTP connection?
nickr
Message 17 of 43
Message 18 of 43
Account number added to "private notes" section Debbie. Download speed is currently @3Mbps. I think the connection problem has something to do with the rain. I removed the cover on the outside of the house where the cables come in to the property and it was pretty wet in there. Just a thought.🤷‍♂️
Message 19 of 43
Hi nickr
Please can you add your TalkTalk account number to the Private Notes section of your Community Profile, we can then take a look at this for you.
Message 20 of 43
Hi Chris. Still dropping. It lasted about an hour when I got home from work, but now it's dropping every few minutes again.
