Internet Connection Keeps Dropping
nickr
Message 43 of 43
Can anyone here help with a problem that I've been having recently with a dropping broadband connection. Over the last few days the connection has started to drop every few minutes, sometimes it lasts a bit longer, but it's off more than it's on just recently. I have run a TalkTalk Health Check and the report says there is a problem with my line. The router (DG8041W) is currently hard wired to my pc with an ethernet cable to eliminate a wifi problem, although I'm pretty sure it's not wifi because the white light on the router (DG8041W) goes red when the connection drops. Thanks in advance. Nick.
42 REPLIES 42
Message 21 of 43
Hi nickr,
How has it been since your last post?
Message 22 of 43
Just so you know, the support team here won't be back online again until Monday.
nickr
Message 23 of 43
My connection is almost completely unusable. I need this to be fixed please. Connection drops every few minutes and then struggles to re-connect.
Message 24 of 43
Yes, same telephone number.👍
Message 25 of 43
I'm sorry to hear this. Can I just confirm, is the telephone number in your Community Profile correct? Please do not post any personal information on the Community.
Message 26 of 43
@nickr,
You seem to have double posted this evening, if you check a couple of steps back.
Staff are not on here at night. I'll re-escalate this thread for them to pick it up in the morning.
Incidentally, the switch off is best for a minimum of 30 minutes, not 20.
nickr
Message 27 of 43
Hi all. I'm back.
Well, after a few months of almost trouble free internet, I'm sorry to report the problem is back. For the last few days connection has been dropping constantly. It doesn't stay connected for more than a few minutes at a time. I've tried the usual stuff switching the router off for 20 minutes to reset the connection, to no avail. The line test is showing a problem with my line. What do I need to do? Thanks in advance.
Message 28 of 43
Also, the speed tests are showing quite low download speeds. 10 Mbps
nickr
Message 29 of 43
Hi all. I'm back.
Well, after a few months of almost trouble free internet, I'm sorry to report the problem is back. For the last few days connection has been dropping constantly. It doesn't stay connected for more than a few minutes at a time. I've tried the usual stuff switching the router off for 20 minutes to reset the connection, to no avail. The line test is showing a problem with my line. What do I need to do next. Thanks in advance.
Message 30 of 43
Thanks for confirming. I've run a test on the line now which has detected a possible fault. The stability looks like it started to improve for 6 days, however I can see that the re-connections have increased again. Is the router still connected to the test socket at the moment please? Can I also just confirm if you've recently tested with a different router please?
Message 31 of 43
Still dropping, but nowhere near as bad as before I connected to the test socket. It's been connected for 1 hour according to my TalkTalk Wi-Fi Hub Dashboard, so it's obviously dropped while I've been out of the house today.
Message 32 of 43
How has the stability been since your last post?
Message 33 of 43
OK, if it continues to drop then we may need to arrange an engineer.
nickr
Message 34 of 43
Well...After what seemed to be a fix, it's started playing up again and the connection is dropping and struggling to re-connect. I'll report back again tomorrow, hopefully this was just a blip.☹️
Message 35 of 43
No Problem 🙂
Message 36 of 43
Thanks. Showing up for 15 hours, so it has probably dropped and reconnected, but nowhere near as bad as it was. Speeds are down slightly compared to what they used to be at 26.75 Mbps compared to 34 Mbps if I remember correctly. Thanks for your help, I'll check back in a few days and see what you all think. Nick. 👍
Message 37 of 43
connection does look stable, lets give it another 48hrs and see how it holds up.
nickr
Message 38 of 43
Connection has been stable for approximately  20 hours wired to the test socket. Looking good! 👍
Message 39 of 43
Good morning,
Thank you for the update. We will re-check the connection stats again first thing in the morning to see how the stability compares now that the router is connected directly at the test socket and we will post back here with an update.
nickr
Message 40 of 43
Now connected to the test socket with the faceplate removed. I'll report back if anything changes.
