Internet LED flashing and can’t connect wireless devices
Fredpimmy
Message 3 of 3
I am unable to connect devices to my TalkTalk router.  Both the internet and wireless LED’s are flashing green. The other 2 LED’s are static green…please help
All cables and connections checked and rebooted router 3 times now.  Reading the previous posts I even left it off for 30 mins last time.
Chris-TalkTalk
Message 1 of 3
Hi Fredpimmy,
Can you also please update your community profile to include your:
  • Name
  • Telephone number
  • Alternative contact number
Message 2 of 3
Which make/model of TalkTalk router do you have? It does sound like it might be an old model.
