Internet cuts out for a couple minutes. ADSL connectivity is down
NeoJester
Message 10 of 10
I have an issue where my internet seems to disconnect for a couple minutes somewhat regularly. When this happens, the light on my hub goes from white to amber and then after a couple minutes, back to white when it now works. My logs says 'ADSL connectivity is down' whenever this happens. How can this be fixed?
9 REPLIES 9
Message 1 of 10
Hi NeoJester
I'm so glad to hear this.
If you do experience any further issues then please let us know.
NeoJester
Message 2 of 10
My internet hasn't dropped in a couple days compared to its regular drops. It might have just been some interference. It's no longer a problem
Message 3 of 10
Hi NeoJester
Do you still need help with this?
Message 4 of 10
Hi NeoJester
Would it be possible to post a photo of your master socket on this thread?
NeoJester
Message 5 of 10
My socket doesn't appear to be like any of the listed main phone sockets. It's most similar to NTE 2000 but the ADSL is on the right and the phone is on the left instead.
I use a microfilter for the DSL since it's what seemed to make sense with the equipment I was given when I first got the hub but I'm not sure if it's right.
My main phone socket has two ports (ADSL, phone) but no horizontal line
Message 6 of 10
Ok thanks for confirming. Just to confirm, which socket do you have please?
Your guide to main phone sockets - TalkTalk Help & Support
NeoJester
Message 7 of 10
I don’t have a landline phone so I don’t know how I’d be able to check if there is noise on the line. I am also unaware of test socket? It only seems like there is one socket. I do not have an alternative router
Message 8 of 10
I'm sorry to hear this. I've run a test on the line now which is clear, however I can see re-connections on the line. Is the voice service ok with no noise on the line? Does your main socket have a test socket please? Do you also have an alternative router that you could test with?
Message 9 of 10
Hi @NeoJester
