Is talk real or a scam?
Edward23
Message 4 of 4
I suspect talk talk is not a real service provider? I have constant problems and need to keep rebooting my modem to get signal. Often I struggle for hours and the help desk says it’s all fine. Am I the only one with this problem? I suspect it’s a deliberately malicious scam.
3 REPLIES 3
Message 1 of 4
Hi Edward23
Do you still need help with this?
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 2 of 4
Hi Edward23
I'm sorry to hear of the issues you are experiencing with the connection.
Message 3 of 4
Of course TalkTalk is a real ISP, it is just that you have some sort of problem that needs fixing.
However, I will need more information, to that end, please can you elaborate by answering these few questions:-
2. What package are you on?
3. What is the exact status of the lights on the front of the router when this happens?
4. If you have any wired connections, are they affected in the same way as wireless ones?
