Master socket problem
Copperhead
Message 4 of 4
I had a text from talktalk with a link to didwefixit and ended up here, so I hope somebody can help. I've had an issue with our telephone line and did a line check, which reported that there was a problem. I have since found that removing the front of the master socket and using a filter removes the issue and also increases our internet speed by 18%. My question is: How do I get a replacement front for the master socket or do I just leave the front off and just use the filter?
3 REPLIES 3
Message 1 of 4
Thanks @Divsec
Copperhead
Message 2 of 4
Thanks Divsec, sounds like a plan.
Divsec
Message 3 of 4
Hi @Copperhead when I had that problem I bought a replacement box, identical to the one I had and used the front. Using the filter is another solution.
Many online retailers supply telecoms sockets and faceplates.
