My Connection doesn't record speeds....
Gliwmaeden2
Message 21 of 21
My Connection is increasingly poor at recording speeds for the week.
This is my most recent check:
It means it's impossible to know if it nosedives on those days when nothing is recorded!
I happened to switch routers during the weekend as I replaced my phone handset at long last. Change of router was only for 10th - 12th and have now switched back again (Sagemcom password couldn't be authenticated when I'd first restarted it, hence the first switch. Back on now and working fine).
So the "no readings" show My Connection not functioning correctly with both routers.
[Incidentally, my phone connection still reads as having a fault, and has done so for over a year..... we switched the routers and checked filters last year,  to no effect, so the final thing for me to check was whether a different handset and extension for plugging in the phone made any difference. They don't. ]
My Connection gives a clean bill of health for my Broadband connection  - but why no data?
Just reporting this again, having mentioned the My Connection speed data problem before, and nothing appears to have been done to sort it.
20 REPLIES 20
Message 1 of 21
I'm really glad to hear this 🙂
Message 2 of 21
It shows a clean line with no gaps for the past week. 😀
Message 3 of 21
Morning @Gliwmaeden2
The fix has now been applied, however I've been advised that it could take 24hrs to filter through. Please let us know how you get on 🙂
Message 4 of 21
Hi again,
The team have identified the issue and are working to resolve it, however it looks like it might be Friday before we have another update.
Michelle 🙂
Message 5 of 21
Thanks. I've passed the screenshot/image back over to the team now.
Message 6 of 21
Yes, @Michelle-TalkTalk, Friday shows no record:
Message 7 of 21
The team have asked me to check to see if you've seen anymore since we passed this over please?
Message 8 of 21
I've passed this over to the My Connection Team now and have asked them to look into why this has happened or if there are any known issues and I'll keep you updated.
Michelle 🙂
Message 9 of 21
Yes, @Michelle-TalkTalk.
They should be told that the product is not working properly.
There are too many glitches with their service, which actually add fog to situations, rather than clarification for customers!
Message 10 of 21
I'm really sorry. I'm not sure why this keeps happening? Would you like me to raise this over to the My Connection Team for you?
Message 11 of 21
My speeds are still basically fine, @Michelle-TalkTalk, but another random check shows an exclamation mark for last Thursday.
Why does this keep happening?
The software for My Connection really doesn't inspire me with confidence!
Message 12 of 21
Message 13 of 21
Thanks! Just found it now.
Seems to be fine.
Message 14 of 21
Afternoon,
If you click on the Community drop down tab, then it now 7th on the list. Apologies this was changed this week.
Message 15 of 21
I can't see at the moment, @Debbie-TalkTalk, as Service Status Dashboard has completely vanished: used to be under "help with your service" in the community menu
Working and packing to go on holiday, so not able to check via My Account.....
The router won't be on while I am away.
Message 16 of 21
Has there been any change over the last 48hrs?
Michelle 🙂
Message 17 of 21
Hi @Gliwmaeden2
The team advised that they are aware of some issues and a fix has been put in place to resolve this.
They said once the data updates this should be resolved, so over the next few days this should start to improve.
Message 18 of 21
Thanks @Gliwmaeden2
I have passed this over to the My Connection team to take a look.
I will let you know as soon as they come back to me.
Thanks again.
Message 19 of 21
I hadn't run the tests in months (and last time reported similar gaps in the readings but not so severe).
This last lot look to be more off than on, so My Connection's own performance has deteriorated.
The reason I was poking around was that I had switched landline phone handsets and after installing the new one, checked whether the fault had cleared (no it hasn't).
So I just ran the other tests for speed and Broadband connection while I was at it.
As I said above, the Broadband has a clean bill of health. Your My Connection data recording does NOT, and other customers as well as myself do mention this from time to time.
Not useful having the My Connection facility at all if it can't be relied upon.
Message 20 of 21
Hi Gliwmaeden2
Can I just check, are you experiencing performance issues with the connection (and that's why you run the tests)
Or do you run the tests just to check the speed?
