yesterday
Quick question as it’s Sunday evening in UK. Experiencing very slow download speeds 10mps and less for a few hours. Have run connection test and was prompted to download the Routethishelps app which I did. Followed all instructions and sent a photo, and provided the code, only to be told by the bot no agents available till Monday! How very frustrating! My question - do I have to start it all again tomorrow or is there anyway I can jump on part way through the process since it’s all on the app and presumably saved by Talktalk? Case number REP-16304240.
5 hours ago
@Philile-TT - download speeds are very slow again, approx 10-12 Mbps. Do you have any idea when there will be an update? Do I continue here on the Community to resolve the issue? It’s great that you are to help.
6 hours ago
Good morning. Yes, I am at home at the moment.
7 hours ago
@BevTalk62 are you currently at home?
7 hours ago
Hi @BevTalk62 I will look into this for you.
yesterday
Agent contact times are given here, @BevTalk62, for both Phone and Chat support:
Forum staff respond Monday to Friday, c 7am - 5pm.
yesterday - last edited yesterday
Yes, I was suggesting that there was a genuine link to Routethis by posting the comment from someone on Reddit, @BevTalk62.
You hadn't mentioned My Connection in your post. People talking about bots are usually referring to the Chatbot etc.
Please be clear about the route that you followed.
yesterday
I thought I had gone via My Connection. In any case a text message to my phone from Talktalk also recommends the RouteThis Helps app. So I think there must be a Talktalk involvement somewhere along the line,MSM from Talktalk
this message is from another issue, but clearly mentions the app in question. I am confused!
yesterday
It's not the TalkTalk bot that is recommending that to you.
Have never seen that, @BevTalk62.
You would normally go via My Connection on the Service Status Dashboard:
https://community.talktalk.co.uk/t5/Service-Status-Dashboard/bd-p/service
Edit: just did a search and got this interesting result:
https://www.reddit.com/r/UKISP/comments/1oebu9z/talktalk_and_routethis_help/
Thank you for the info, I will wait for contact tomorrow, out of curiosity. Why does the talktalk support bot recommend you to download that app? All just a bit frustrating and confusing?
As usual, more comprehensive advice and info from the community. Thank you
yesterday
That's a third-party app and nothing to do with TalkTalk. The support team will pick your topic up tomorrow.
