My VPN connection to my office wont work with talk talk
daveburrows67
Message 5 of 5
Hiya...
I have posted before but have never received a solution. Occasionally I need to connect to my head office at work through a VPN they set up. I have checked and it is the standard windows vpn that they use. When I connect using my phone as a hot spot there is no issue... connecting at a friends on Plusnet, no issue, but at Home on talk talk I cannot connect... please please can I finally get a solution to this, its causing me headaches having to keep using my hotspot when I need to connect to head office!!
Many thaks in advance
4 REPLIES 4
Message 1 of 5
Hi Dave
daveburrows67
Message 2 of 5
Hi Debbie,
 yes please that would be perfect to try a new Router
Message 3 of 5
Hi Dave
Would you like me to send a different make and model of router for testing?
Skynet_TX
Message 4 of 5
Hi @daveburrows67,
Please can you confirm what model of router you are currently using, I know you mentioned it in your older posts, but just wanted to double check what you are using now.
The TalkTalk staff on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
