Netgear Wifi extender
Kimsman
Message 3 of 3
Is it actually possible to add a Netgear Wifi extender when using an Eero 6 router? Or, do TalkTalk give Eero extenders to their customers? Asking for my 81 year old mum. Ta
Kimsman
Message 1 of 3
Thank you Keith. 👍
Message 2 of 3
The proper way to gain extra coverage is to buy another Eero from TalkTalk (not sure if Talk ones are branded & made incompatible with the Amazon ones), as it is designed to be a mesh system. Any extender may work, but it will depend on the exact model, if it needs to connect via WPS, I don't think the Eero has that functionality.
Call the TT loyalty dept 0345 1725157 if you want an extra Eero.
