No blue light on router (Wi-Fi Hub v1.05t)
dennisl
Message 12 of 12
This morning there was no internet connection or blue light showing on the router.
After re-booting the router, the internet came back on , but the blue light is still off.
Everything looks ok in the router dashboard.
I'd like to restore the blue light though and would appreciate your advice on this.
11 REPLIES 11
Message 1 of 12
Hi Dennis
That's great news, thanks for letting me know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
dennisl
Message 2 of 12
The new router is working fine.
Many thanks
Dennis
Message 3 of 12
dennisl
Message 4 of 12
Thanks Debbie.
I'll advise on this asap.
Message 5 of 12
Hi dennisl
dennisl
Message 6 of 12
Yes please.
Many thanks for your assistance.
Message 7 of 12
OK, thanks for trying. We can send another router, would you like us to arrange this?
dennisl
Message 8 of 12
I reset the router, but the blue light is unfortunately still not showing.
Message 9 of 12
Thanks, could you try resetting the router to factory default settings, this should hopefully fix the light issue - Restore your router to factory settings - TalkTalk Help & Support
dennisl
Message 10 of 12
Profile updated, as requested.
Chris-TalkTalk
Message 11 of 12
Hi dennisl
  • Name
  • Telephone number
  • Alternative contact number
