PPTP VPN Not working
Cassie90
Message 12 of 12
Good afternoon, my IT has confirm we have a PPTP VPN server at work and I'm unable to connect to work from home. I have called numerous times and no one has actually provided a solution that works and have been hang up the call a few times.
So from reading this forum I either need an update of my firmware  like this person had
https://community.talktalk.co.uk/t5/Fibre/VPN-stopped-working/td-p/2889120
Or like this other person I would need a new router as i have the exact same problem
https://community.talktalk.co.uk/t5/Broadband/PPTP-VPN-Outbound-stopped-working/td-p/2838346
Router is - Sagemcom FAST5364 3.00
Please advise as this is getting urgent and fustrating knowing is a well knowed error with your routers and no one within the company seems to be able to help
11 REPLIES 11
Message 1 of 12
Hi Cassie
I have posted on your other topic to advise the below:
Hi Cassie90
I have made a change to your router firmware, please can you retest?
Message 2 of 12
Hi, I just received a new router and I have the same problem again. Can this please be looked into as a matter of urgency as I need to be able to work from home? Thank you
Message 3 of 12
Hi @christinewilkinson1960
Please can you create a new topic on the Community, I can then take a look at this for you.
Message 4 of 12
good morning,
i have a problem getting into my work computer i believe its talk talk that are blocking the pptp vpn, please can i log this an an urgent matter
CHRISTINE WILKINSON
Message 5 of 12
How are you getting on? Is the connection now ok?
Message 6 of 12
Hi Cassie90
Thank you 🙂
The firmware has now been updated, please can you retest and let us know how the connection compares.
Message 7 of 12
Hi Debbie,
you can do this now as I'm not currently at home
Message 8 of 12
Hi Cassie90
Thank you. I will need to make a change to your router firmware, when would be the best time to do this?
We advise to keep the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
Message 9 of 12
hi Debbie, this has been added
Message 10 of 12
Hi Cassie90
Apologies for this.
Please can you add your TalkTalk landline number to your Community Profile, we can then take a look at this for you.
Message 11 of 12
This requires a manual change of firmware, that only TalkTalk can do via this forum.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
