Poor WiFi coverage even with extender
on 09-01-2022 07:02 PM
Message 11 of 11
I live in a small bungalow. I get good WiFi in two rooms but in the other 3 the signal is weak, it regularly drops out and the speed is slow. I was sent a talktalk extender when I renewed my Talktalk contract and now the signal is good in the room I put that in but the 2 other room are still just as bad. I don't know what else to do to solve this problem. Can anyone advise me on how to fix this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
10 REPLIES 10
on 14-01-2022 10:15 PM
Message 1 of 11
Sorry, I don't know what happened, the reply to your PM I sent yesterday or the day before & seems to have got lost. I have sent another reply. Please let me know if you don't get that one.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-01-2022 06:50 PM
Message 2 of 11
Hi Keith
I have sent you a pm.
Scramble_cam
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-01-2022 09:27 AM
Message 3 of 11
If you can just send me screenshots of each of the views from the analyser & I will take a look. I will need to know the name of of your WiFi networks (SSID).
When you include them, please use the Insert Photo button on the toolbar and set it's Size Parameter to Large.
Feel free to PM them to me if you want.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-01-2022 09:06 AM
Message 4 of 11
Hi Keith
I would like it if you could do this. How can I arrange this?
I did download wifi analyzer app and tested it in the two rooms I don't get signal and there was occasionally distant interference from neighbours routers but the big thing I noticed was my wifi signal was very low and the estimated distance from the router or extender was 10s of meters even though the distance was less than 10m.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-01-2022 03:13 PM
Message 5 of 11
Unless you know about WiFi interference I am offering to do all of the analysis, totally free of charge for you, it is not just the WiFi channel selection. Plus this must be done considering both the router & the WiFi extender.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-01-2022 03:10 PM
Message 6 of 11
Hi Keith
Thanks for your reply. I would appreciate some help with this. How should I go about doing the WiFi analysis etc?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-01-2022 03:08 PM
Message 7 of 11
Thanks for the replies. I will try looking at any interference and changing the channel. Hopefully I will be tech savvy enough to be able to manage this but I'm not sure.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 11-01-2022 11:29 AM
Message 8 of 11
If you want any help sorting this problem, I can help a lot with using a free WiFi analyser and I can analyse the results for you & tell you what needs to be done to rectify it.
I have found a similar problem with a friend of mine who lives in a bungalow (this is nothing to do with being a bungalow, it could easily apply to any property type). Although the WiFi signal should have reached one problem room without issue, there was a lot of WiFi interference from other networks in that room only.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 10-01-2022 08:26 AM
Message 9 of 11
Hi Scramble_cam
Have you tested different wireless channels to see how the connection compares? Change your wireless channel
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 09-01-2022 07:45 PM
Message 10 of 11
Hi @Scramble_cam,
Have you tried using a smartphone App like this to see what Wi-Fi channels are being used within range of your smartphone. This would help you see if there are other networks (i.e. your neighbours routers) that are using the same, or similar, channel to yours that could be interfering with your signal.
If the App helps you identify better channels that you could be using you could then change your router to use those better channels :
https://community.talktalk.co.uk/t5/Articles/Change-your-wireless-channel/ta-p/2204684
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Related Content
- Confused and Frustrated – No Internet, Mixed Info, and No Updates in Full Fibre
- Full fibre 500 not getting even minimum speed from that in Full Fibre
- Wi-Fi unstable in Fibre
- New Eero Fibre 150 - signal reach problems - adding another Eero? in Fibre
- Help required setting up Eero with Fibre 65 in Fibre
