Problems with 5Ghz Wifi
langstrorth2
Message 15 of 15
I've been having problems with a few devices (chrome books used as on the wall displays) constantly losing access to see other devices on my network. I think I eventually tracked this down to the fact the devices with the problem were connected to the 5Ghz signal and not the 2.4Ghz signal.
As a temp measure I've now split the SSID names - so the 2Ghz and 5Ghz signals have different SSID names - and this has forced everything onto the 2.4Ghz signal for now - and the problem I think is solved. But why would this be the case? Is there an issue with the talktalk router 5Ghz signal?
14 REPLIES 14
Message 1 of 15
That does sound promising 🙂
Message 2 of 15
So far so good. I've got the new router up and running - and using a combined 2.4 and 5Ghz SSID, and so far it seems to be OK.
Message 3 of 15
Anonymous User
Message 4 of 15
Thanks for the update and we'll check back in with you tomorrow to see how you're getting on.
Michelle 🙂
Message 5 of 15
Received thank you (very quickly). I'm going to swap it out later today to try the new one.
Anonymous User
Message 6 of 15
Morning Graham,
Just checking back in to see how you're getting on and if the replacement router has arrived?
Message 7 of 15
No Problem 🙂
Message 8 of 15
Many thanks
Graham
Message 9 of 15
A router is on the way.
langstrorth2
Message 10 of 15
I think swapping the router out would be worth trying please.
Message 11 of 15
Would you like to swap out the router to see if its at fault ?
langstrorth2
Message 12 of 15
Running the router on combined 2.4Ghz and 5Ghz just doesn't seem to work, I've had to stick with using two SSID's - one for 2Ghz and one for 5Ghz (which basically never works)
In addition devices are constantly kicked off or seem to lose their DNS (e.g. I can't look up local devices by their local name - having to revert to using their IP address).
I'm afraid to say this router isn't nearly as good as the old BT one I had.
Anonymous User
Message 13 of 15
How are you getting on?
Message 14 of 15
If you have split the SSIDs then you should make sure that the device you want 5GHz to connected is on the right one, check the wifi connection settings by device and if necessary "forget" the other one.
Anonymous User
