8 hours ago - last edited 8 hours ago
I have not long swapped out my old router for a different brand due to WiFi issues. This has been working fine for WiFi, but now I am faced with multiple router reboots every day.
Can you please investigate why this is the case?
Many thanks in advance,
Steven.
6 hours ago
You're Welcome 🙂
6 hours ago
Hi Karl,
Thanks for this.
Steven.
7 hours ago
Engineer booked in for tomorrow AM (8-1).
7 hours ago
Hi Karl,
That is all fine.
Steven.
8 hours ago
We'll book an engineer to investigate. This is free of charge in most cases but a charge of £75 can apply in some circumstances.
Should there be :
Damage to the Openreach socket or wiring within your property
Damp in the master socket or wiring is the underlying cause of the issue
Non-TalkTalk equipment is causing the fault, for example a 3rd party router or phone
Non-standard wiring is causing the issue, for example DIY wiring to an extension socket
An Adult must also be present.
If you miss the agreed appointment or refuse access to the Engineer you will still be charged.
We'll book the next available engineer unless you specify a day, either AM or PM.
Please confirm by reply that you accept the engineer conditions.
8 hours ago
Hi Karl,
That would be great and if I can manage to get a phone from family I will test and report back.
Steven.
8 hours ago
The next option is to arrange an engineer, do you want to do this now ?
8 hours ago
Hi there,
I swapped two WiFi hubs. I had a Huawei one and swapped to a Sagem one. I sent the Huawei one back.
Many Thanks in Advance,
Steven.
8 hours ago
Hi Karl
I don't actually have a telephone that I can plug into the phone socket.
Is there anything else I can do?
Steven.
Tests are showing a possible issue with the copper line.
Can you check the home phone connection and tell me if there is a clear dial tone or noise / crackles on the line ?
8 hours ago
Hi @Doozy you don't mention the brand of the two routers?
If you still have the first router try that and thus rule in, or out, the rebooting router.
