Router fails to allocate an IP address for visiting devices
Barbs1
Message 16 of 16
Router model:                   FAST 5364 Sagemcom
TalkTalk Wi-Fi Hub
Hardware Version           FAST5364 3.00
Software Version             SG4K100136
GUI Version                       5.6.1
We were supplied with the above router several months ago due to connection issues.  Whilst having visitors at Christmas we noticed that people were unable to connect to our passworded wifi.  Investigations  showed that whilst DHCP is enabled the router  does not allocate an IP address to devices that are not included in the table of reserved IP addresses.  This applies to both wired Ethernet connections and WiFi connections.
In addition, the router deletes entries from the reserved IP address table if they are not used for a few days, and because DHCP does not work, they have to be re-entered into the reserved address table. Devices that are used regularly (daily or every few days) remain in the reserved IP address table.
This is very tiresome and unless someone has a solution it would appear that the router has a fault and therefore needs replacing.
15 REPLIES 15
Message 1 of 16
Hi Barbs1
Thanks for your reply, that's great 🙂
If you do experience any further issues then please let us know.
Message 2 of 16
So far so good thanks.  Waiting for a visitor to retest!
Message 3 of 16
Hi Barbs1
How has the connection been since your last post?
Message 4 of 16
Glad the solution helped, any issues, just post back here 🙂
Message 5 of 16
Thank you for your help.  This seems to have worked for now.  If the problem reappears we'll be in touch.
Message 6 of 16
Hi Barbs1
Please can you power down the router for a full 30 minutes and then retest again once the router has been switched back on?
Message 7 of 16
Thank you. Will this definitely fix the problem?  Will we need to re-enter existing IP addresses and settings ie is it like a factory reset?
Message 8 of 16
Hi Barbs1
The firmware has now updated to the latest version - 158.
Message 9 of 16
Hi Barbs1
I will start the update now and I will post back to confirm once it's completed.
You don't need to do anything on your end.
Message 10 of 16
Our router is on all the time so anytime is good for us.  Please confirm that you are doing this update directly and that there is nothing we need to do our end.  Thanks.
Message 11 of 16
Hi Barbs1
Sorry for the delay.
I will update your router firmware to the latest version, when would be the best time to do this?
We advise to leave the router switched on without being rebooted whilst we update the FW. This should take no longer than 15 minutes to update.
Message 12 of 16
Thanks for that tip.  Have done so now.
Message 13 of 16
OK, for the support team to do this you need to make sure that your personal details including TalkTalk phone number and/or account number are complete on your community profile (click here) so that they can link your forum identity with your account and then wait for them to respond.
Barbs1
Message 14 of 16
No it's enabled.  Did switch off and turn back on to see if it made any difference.  Perhaps TalkTalk need to send us a firmware update?
Message 15 of 16
Have you switched off DHCP?
