Router forcing my devices to reset IP lease every 15 mins
Riquez
Message 26 of 26
I am having an issue where the router seems to be forcing devices on my network to renew the IP lease. This is causing a big problem for me being able to stream music, video etc in the house because playback will exit every 15 mins when this event occurs.
It happens at exactly 11, 26, 41 & 56 mins past every hour.
After some research on other forums I heard it is a bug in TalkTalk routers not following protocol.
- Can TalkTalk provide me a different router without this issue?
- What other options do I have?
Here is an example of the IP lease changing on my RaspberryPi
(journalctl -r)
Sep 15 10:11:59 raspberrypi avahi-daemon[374]: Registering new address record for 192.168.1.102 on wlan0.IPv4.
Sep 15 10:11:59 raspberrypi avahi-daemon[374]: New relevant interface wlan0.IPv4 for mDNS.
Sep 15 10:11:59 raspberrypi dhcpcd[455]: wlan0: adding default route via 192.168.1.1
Sep 15 10:11:59 raspberrypi dhcpcd[455]: wlan0: adding route to 192.168.1.0/24
Sep 15 10:11:59 raspberrypi avahi-daemon[374]: Joining mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.102.
Sep 15 10:11:59 raspberrypi dhcpcd[455]: wlan0: leased 192.168.1.102 for 86400 seconds
Sep 15 10:11:54 raspberrypi dhcpcd[455]: wlan0: probing address 192.168.1.102/24
Sep 15 10:11:54 raspberrypi dhcpcd[455]: wlan0: rebinding lease of 192.168.1.102
Sep 15 10:11:54 raspberrypi dhcpcd[455]: wlan0: deleting default route via 192.168.1.1
Sep 15 10:11:54 raspberrypi dhcpcd[455]: wlan0: deleting route to 192.168.1.0/24
Sep 15 10:11:54 raspberrypi avahi-daemon[374]: Interface wlan0.IPv4 no longer relevant for mDNS.
Sep 15 10:11:54 raspberrypi avahi-daemon[374]: Leaving mDNS multicast group on interface wlan0.IPv4 with address 192.168.1.102.
Sep 15 10:11:54 raspberrypi avahi-daemon[374]: Withdrawing address record for 192.168.1.102 on wlan0.
Sep 15 10:11:54 raspberrypi dhcpcd[455]: wlan0: 10 second defence failed for 192.168.1.102
Sep 15 10:11:54 raspberrypi dhcpcd[455]: wlan0: hardware address 00:00:00:00:00:00 claims 192.168.1.102
Sep 15 10:11:53 raspberrypi dhcpcd[455]: wlan0: hardware address 00:00:00:00:00:00 claims 192.168.1.102
25 REPLIES 25
Message 21 of 26
Thanks Michelle, I've updated my info.
Message 22 of 26
  • Name
  • Telephone number
  • Alternative contact number
Message 23 of 26
yes. my service went live about 4 weeks ago & this issue is ongoing since then.
Message 24 of 26
Are you still seeing this issue ?
Message 25 of 26
The way that DHCP leasing works is that the router allocates the IP address & informs the client of the lease time (normally a day on TT routers). Then when 50% of the lease time has expired, it is the responsibility of the client to request an extension to that lease that the DHCP server will grant. You either have an issue with your clients, or something else is causing the problem.
